It is currently Fri Mar 29, 2024 5:41 am
[ 6 posts ] |
2015 Gtr 35 mikuni/e-pump install ?
Pintail1992
Just received my carb kit and and exhaust from Delta. Delta said I didn't have to but recommended that I run an E-pump. Any of you guys have some insight or any pics of how you mounted your E-pump to the motor??
Thu Oct 12, 2017 11:43 am |
Russ
Re: 2015 Gtr 35 mikuni/e-pump install ?
I run mine 6-12" from the gas tank through (currently) 8' of fuel line to the engine. I was running about 15', but it was time to put new line on and didn't use as much. It's not vibrating with the engine with it in the boat.
Thu Oct 12, 2017 11:47 am |
Pintail1992
Ok thanks. So you did you bypass your manual pump all togheter or leave it inline. May be a dumb question but I'm new to do any mods on these motors.
I see a lot of guys say you don't need to run an e-pump But I got it so I figured I would give it a shot
Thu Oct 12, 2017 12:09 pm |
Russ
Never had a stock pump installed. Built this engine from a parts engine and some aftermarket additions myself.
Thu Oct 12, 2017 12:31 pm |
MaXXis85
if your stock fuel pump is working fine, You will be fine.
Fri Oct 13, 2017 6:01 am |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
I got 12-15 ft of fuel line(5/16), impulse type pump, tank built in to console, primer bulb and fuel filter within the 1st 2 ft., works good for me, and I am running a mikuni carb. with 3/8 line in my other boat had issues kept losing prime at low speeds.
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
Fri Oct 13, 2017 8:01 am |
[ 6 posts ] |
Users browsing this forum: No registered users and 316 guests |
