River Runner
New coils and timing key?
Looking for a little info. I’m replacing the coils on a 2004 35hp, the new coils came with the new offset timing key. Does anyone know if this key advances or retards the timing? And how much? Also what size is the flywheel nut? 32 mm?
Fri Oct 13, 2017 9:39 am |
Will C
Re: New coils and timing key?
Someone else on here had that question a while back and he found an answer. Not sure where the thread is. Seems like his was a 32 . For a 35 non cdi I'm not sure why there would be an offset key
Fri Oct 13, 2017 10:06 am |
Choot'em
Joined: Sun Nov 04, 2012 4:52 am Posts: 58 Location: Selmer,TN
Just did it on my 2009 gtr it is to advance the timing seems like it burns better during the combustion over a stock key...should also give you a little more top end power. I believe it was a 32mm socket on the flywheel but as well
Fri Oct 13, 2017 10:44 am |
River Runner
It looks like the key they sent me would retard the timing?(rotating flywheel counter clockwise)
Fri Oct 13, 2017 11:34 am |
MaXXis85
1-1/4" socket works too!
Fri Oct 13, 2017 12:34 pm |
Choot'em
It will with I believe the dotted end out and advance with dotted end towards the motor
Fri Oct 13, 2017 1:23 pm |
River Runner
Yeah it says to install with the painted end out, which I believe will retarded timing. Have heads and cam in this one so was thinking about advancing timing. Going by the book for now, paint out. Can pull it apart again if I have to...
Fri Oct 13, 2017 1:37 pm |
Choot'em
Yeah just finished this one myself
Fri Oct 13, 2017 2:14 pm |
BoatDR
Yes, it retards the timing.
The new coils are made differently and the key re-sets the timing back to the original spec.
Sat Oct 14, 2017 2:16 pm |
jc
Do the new coils for the non cdi motors have the built in rev limiter?
Sat Oct 14, 2017 7:28 pm |
cb5331
no
Mon Oct 16, 2017 9:30 am |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
My rev limiter can hold a cold beer too!
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
Mon Oct 16, 2017 10:33 am |
