It is currently Fri Apr 19, 2024 4:01 pm
Reply to topic  [ 3 posts ]
 Cleaned carb -- I created a problem HELP! -- Slide stuck now
Post Cleaned carb -- I created a problem HELP! -- Slide stuck now
Hard starting so set to cleaned the carb.
In the past I'd always just took it apart prayed each jet and all. Always worked for a year or so.
THOUGHT I'd really do a good job cleaning the time so I used the "heavy duty" cleaner that you actually soak. Seemed to work well - keep it away from the plastic parts.
I didn't pull the slide. Is there plastic on the slide?
Cause the slide is now stuck. Dammit lookslike I screwed up!!
Help!
What do I need to do to get this fixed?
May have cost myself some$$$$
Wed Oct 18, 2017 7:49 pm
Post Re: Cleaned carb -- I created a problem HELP!
This is a single mikuni carb with non cdi MB.
Wed Oct 18, 2017 7:52 pm
Post Re: Cleaned carb -- I created a problem HELP! -- Slide stuck
pm sent
#TheGhostBoat
Wed Oct 18, 2017 8:10 pm
Users browsing this forum: No registered users and 387 guests
