Cleaned carb -- I created a problem HELP! -- Slide stuck now
Hard starting so set to cleaned the carb.
In the past I'd always just took it apart prayed each jet and all. Always worked for a year or so.
THOUGHT I'd really do a good job cleaning the time so I used the "heavy duty" cleaner that you actually soak. Seemed to work well - keep it away from the plastic parts.
I didn't pull the slide. Is there plastic on the slide?
Cause the slide is now stuck. Dammit lookslike I screwed up!!
Help!
What do I need to do to get this fixed?
May have cost myself some$$$$
