It is currently Mon Mar 23, 2026 4:13 pm
Reply to topic  [ 14 posts ]
 Is my motor stock
Post Is my motor stock
I have a 2015 gator tail 35 in the water it doesn't bounce the rev limiter till about 4700 rpm is that factory or is there something done to the engine I bought the engine used and never thought to ask
Tue Nov 28, 2017 7:07 pm
Post Re: Is my motor stock
Sounds like you have 4750 rev limit coils on the motor.
Are you running those rpm’s consistently? Or just when the prop comes out the water?
Tue Nov 28, 2017 7:12 pm
You are turning 4700 rpms in the water? If so, then no I doubt it is stock. The stock CDI coils do limit rpms at 4700 rpms OOW but I highly doubt you're running those RPMs in the water with a stock motor unless your prop is worn like crap. What speeds are you seeing and do you have it trimmed right?
Tue Nov 28, 2017 7:13 pm
The prop is in the water at 4700 rpm but trimmed a little high I run best trimmed down at about 4400 to 4500 rpm that's where I run consistently it goes about 24 to 26 mph
Wed Nov 29, 2017 9:13 am
Sounds like you’ve got the lower pitched prop with a stock motor.
I could be wrong though.
Wed Nov 29, 2017 9:26 am
Or wasted prop
Wed Nov 29, 2017 11:39 am
Wed Nov 29, 2017 11:56 am
That is alot of RPM's to be going nowhere very fast.
Wed Nov 29, 2017 12:24 pm
Should I try a new prop what should I get
Wed Nov 29, 2017 1:31 pm
Try a big blade
Wed Nov 29, 2017 3:12 pm
Has anyone ran the hammer prop or is it to much prop
Wed Nov 29, 2017 10:25 pm
Prob too much
Wed Nov 29, 2017 10:55 pm
Hammers are NOT for stock motors.
Your prop is worn more than likely.
Thu Nov 30, 2017 6:05 am
For a 35 that does sound high. However i do run my best speeds around 4600-4700 rpm on a stock 37.
Sun Dec 03, 2017 6:56 pm
cron
