It is currently Sun Jun 09, 2024 2:01 pm
[ 2 posts ] |
oil and Crancase vent tube
prodrive1999
I have a 2006 prodrive with 60 hours. Has dual mikuni carbs, stroker rods, flat pistons, cam, roller rockers and titanium pushrods. One head has a tube coming out that goes nowhere which is called a crankcase breather hose i believe. I have noticed oil drips out of it onto the exhaust when running and checked the oil level and it was low. Added almost a quart to get the level full again. Gets low after about 3 fishing trips. Could the piston rings be bad or would more compression from the mods just cause oil to seap out. Thanks
Sat Feb 17, 2018 9:08 pm |
Russ
Re: oil and Crancase vent tube
Head gasket can case that, rings, or anything that causes excessive case pressure. Get a breather filter from AutoZone and see if that doesn't help, and pull the valve covers to see if you might have a blown head gasket.
Sat Feb 17, 2018 9:20 pm |
[ 2 posts ] |
Users browsing this forum: No registered users and 167 guests |
