27 hp prodrive fuel issue http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=71822 |
Author: | brysonandrus1986 [ Mon Jan 01, 2018 2:39 pm ] |
Post subject: | 27 hp prodrive fuel issue |
ok so i bought this prodrive used. it is an early 2000 model. manual reverse. just recently during the last two hunts it has ran fine for about 10 min then it would lose power, if i pump the ball it would regain power and run fine. now it wont stay running at all. i have changed fuel lines, ball and fuel pump. only thing i havent done yet is clean the carb. just wanted some input before i tear it down. thanks |
Author: | brycecheramie [ Mon Jan 01, 2018 6:44 pm ] |
Post subject: | Re: 27 hp prodrive fuel issue |
Clean carb thoroughly. Report back |
Author: | Russ [ Mon Jan 01, 2018 6:49 pm ] |
clean the carb, adjust the float. sounds like it's emptying the bowl and the fuel pump cant keep up. since you've replaced the fuel pump, it could be gunk in that passage. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
Author: | brysonandrus1986 [ Mon Jan 01, 2018 9:10 pm ] |
Thanks guys I will take it off and clean it tomorrow. Ill keep y'all posted Sent from my SM-N950U using Tapatalk |
Author: | 50fps [ Tue Jan 02, 2018 8:59 am ] |
Pay particular attention to the fuel shut off solenoid, they really get gummed up. |
Author: | cb5331 [ Tue Jan 02, 2018 3:03 pm ] |
Author: | brysonandrus1986 [ Tue Jan 02, 2018 6:46 pm ] |
Well I got the carb cleaned up which it really wasn't dirty and its still doing it. I have to choke it every time to start it . it will die as soon as I take it off choke Sent from my SM-N950U using Tapatalk |
Author: | brycecheramie [ Wed Jan 03, 2018 6:24 am ] |
Author: | brysonandrus1986 [ Wed Jan 03, 2018 7:20 am ] |
Author: | brycecheramie [ Wed Jan 03, 2018 7:29 am ] |
Author: | brysonandrus1986 [ Wed Jan 03, 2018 7:31 am ] |
Author: | brycecheramie [ Wed Jan 03, 2018 7:37 am ] |
How about bubbles/air leaks in your fuel filter? |
Author: | brysonandrus1986 [ Wed Jan 03, 2018 7:48 am ] |
Author: | brysonandrus1986 [ Wed Jan 03, 2018 6:02 pm ] |
Just checked and the fuel pump is definitely not pushing any fuel. Has to be something with the pulse line ?? Sent from my SM-N950U using Tapatalk |
Author: | Miker17 [ Sun Jan 07, 2018 8:21 pm ] |
When u clean carb also make sure to take the accelerator pump on the carb apart and clean it out. I have same motor with same problem. I changed all fuel components as well. Same problem still. Recleaned carb, taking apart the accelerator pump this time then Also the put a electric fuel pump on it and ran like a champ. |
Author: | Miker17 [ Sun Jan 07, 2018 8:23 pm ] |
I also thought the pulse pump was weak, replaced that and was still the same. Put e fuel pump on it |
Author: | brysonandrus1986 [ Sun Jan 07, 2018 10:28 pm ] |
Author: | Russ [ Mon Jan 08, 2018 8:40 am ] |
Get the facet posi-flow. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
Author: | Miker17 [ Mon Jan 08, 2018 8:59 am ] |
I used Mr. Gasket 42S Electric Fuel Pump. $40 on Amazon. I believe Napa has one as well search forum for that part number. I assume ur fuel tank is in the front of ur boat? |
Author: | brysonandrus1986 [ Mon Jan 08, 2018 8:59 am ] |
Author: | brysonandrus1986 [ Mon Jan 08, 2018 9:00 am ] |
Author: | Miker17 [ Mon Jan 08, 2018 4:47 pm ] |
Did u check ur fuel tank vent and make sure the pick up tube isnt cracked and tight |
Author: | brysonandrus1986 [ Mon Jan 08, 2018 4:49 pm ] |
Author: | brysonandrus1986 [ Thu Jan 11, 2018 7:24 pm ] |
Got a Mr. Gasket fuel pump and she is running like a champ!! Will put her in the water tomorrow for the real test. I will update tomorrow. Thanks to all of you who took the time to help me out. Sent from my SM-N950U using Tapatalk |
Author: | Russ [ Thu Jan 11, 2018 8:08 pm ] |
Get a spare or make sure you have a primer bulb. Those pumps are good, but they give no warning when they're gonna die. The facets have a longer lifespan. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
Author: | brysonandrus1986 [ Thu Jan 11, 2018 8:37 pm ] |
OK will do Sent from my SM-N950U using Tapatalk |
Author: | Miker17 [ Fri Jan 12, 2018 12:13 pm ] |
Good to hear let us know |
Author: | brysonandrus1986 [ Fri Jan 12, 2018 12:34 pm ] |
Should I bypass the original fuel pump? Also noticed it runs better with the pulse line disconnected from the old pump Sent from my SM-N950U using Tapatalk |
Author: | Russ [ Fri Jan 12, 2018 1:41 pm ] |
One fuel pump only. Don't run 2. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
Author: | brysonandrus1986 [ Fri Jan 12, 2018 2:04 pm ] |
Author: | Russ [ Fri Jan 12, 2018 5:15 pm ] |
Get a bolt, pull the fitting, plug the hole. That way you can always go back to it if you want to. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
Author: | brysonandrus1986 [ Sat Jan 13, 2018 3:50 pm ] |
Went for a run and noticed it was stalling a bit when I tried to open it up to fast. Turned up the idea. Tiny tach is reading 2120 at idle. Is this speed OK/safe?? Sent from my SM-N950U using Tapatalk |
Author: | Russ [ Sat Jan 13, 2018 7:38 pm ] |
Not really. You need to idle around 1200-1600 (don't know what the manual calls for, though, but that's a good ballpark). If it's stumbling off idle, the carb needs tuning or upgrading. Read up on tuning carbs. The concepts are the same for most carbs, they just don't all look the same. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
Author: | brysonandrus1986 [ Sat Jan 13, 2018 7:41 pm ] |
OK thanks Sent from my SM-N950U using Tapatalk |
Author: | brysonandrus1986 [ Fri Jan 26, 2018 8:26 pm ] |
Haven't reported in a while. The Prodrive doesn't miss a beat now with the new fuel pump. Thanks again to everyone who helped out. About to upgrade to a bigger motor and boat [WINKING FACE] Sent from my SM-N950U using Tapatalk |
