It is currently Fri Apr 19, 2024 7:02 pm
[ 7 posts ] |
Diaphragm pump going bad/leaking
nuccifish06
Joined: Tue Sep 16, 2014 6:36 pm Posts: 108 Location: Sunrise, FL
I've got a 23hp van and I'm on my 3rd diaphragm pump in 4 years. They keep pumping fuel out the little hole on the top and motor runs itself out of fuel. Is this a common problem due to ethanol fuels deteriorating the inside or am I blowing a leak in it priming the line with an electric fuel pump I installed because my tank is located in the front. The pump is only a 2-4 pump. Couldn't find anything on this in a search.
_________________ 1438 Jon / 23hp MBLT
Tue Jan 09, 2018 8:36 am |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
Re: Diaphragm pump going bad/leaking
Either do away with diaphragm pump or electric one. No need for both. I have never run an electric fuel pump and the only fuel problems have been air leak and a primer bulb leak. Your electric pump might be what is causing diaphragm to start leaking, if your tank is not vented and it swells up it is putting pressure on that diaphragm also.
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
Tue Jan 09, 2018 9:17 am |
nuccifish06
Got it. Thanks. Do you think I can keep the electric pump just to initially prime the line still since I removed the primer ball?
Tue Jan 09, 2018 9:31 am |
4Cody4
Joined: Thu Mar 31, 2011 11:21 am Posts: 2530 Location: Land of 10,000 Lakes
I’d rather have the primer ball than the electric pump myself.
_________________ "Two people in this world wear helmets, and that's dare devils and pussies." - Willie Braun
Tue Jan 09, 2018 9:52 am |
Russ
use the primer bulb to prime, and either the electric or the diaphragm pump to feed the engine. I use the Facet solid state e pump (posi flow, used to be the cube).
Tue Jan 09, 2018 9:55 am |
MaXXis85
primer bulb and diaphragm pump. E pumps are not needed and are bandaids.
Tue Jan 09, 2018 9:59 am |
nuccifish06
OK. Thanks again for the advise!
Tue Jan 09, 2018 11:19 am |
[ 7 posts ] |
Users browsing this forum: No registered users and 398 guests |
