It is currently Sat Mar 21, 2026 11:45 am
Reply to topic  [ 8 posts ]
 Mud Motors and Salt Water?
Post Mud Motors and Salt Water?
What do you guys do to clean (or use to keep clean) your motors after a day on the brackish or salt waters?
Lead, Follow or Get The Hell Out Of The Way!!!!
1754 Gator Trax Hybrid, Hunt Deck ,with MB 4400 Black Death HDR, Duck Slaying, Mud Slingin Machine!!!
Wed Jan 10, 2018 6:02 am
Profile YIM
Post Re: Mud Motors and Salt Water?
I rinse my motor motor down with fresh water as soon as I get home. I used to spray Wd-40 shit like that but didn’t find it doing much good. I have 350 hrs on my motor running nearly all salt/brackish water and the only problem I find I have is the Exposed shaft in between the seals and prop start to rust. Took 250 hrs to cause any problems last round. Oh and of course the exhaust looks like shit
Wed Jan 10, 2018 6:17 am
I have cases upon cases of corrosion-X. The thick shit in the spray can.
When I had my motor brand new, I sprayed the entire motor down with it, and that helped out a lot.
Wed Jan 10, 2018 6:49 am
Fresh water rinse when I get home and a good dousing of Water Displacement Forty on everything.
Wed Jan 10, 2018 9:31 am
MMT Moderator
I wrap my spark plugs with electrical tape to prevent the arching and grounding out on the heads.
Wash motor with fresh water
Corrosion-X the whole thing before the 1st run to build a base layer.
GTB 1860 w/ 2019 GTR40XD-HO
Wed Jan 10, 2018 11:12 am
Can you explain what you mean by wrapping the spark plug with electrical tape? I've never done it but I it sounds like a good idea.
Wed Jan 10, 2018 10:12 pm
Carwash after every trip. And I also use a corrosion protectant spray that looks like crap, but when you take it off with a mild degreaser and water the motor still looks new
Thu Jan 11, 2018 2:08 am
Thu Jan 11, 2018 4:44 am
Profile YIM
cron
