| Motor decisions http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=71901 |
| Author: | Greenhead69 [ Sun Jan 14, 2018 10:16 am ] |
| Post subject: | Motor decisions |
Have a MB 45 mag rite now. Love the motor just want something a little newer and with reverse. Was leaning towards a boss drive 4400 Black Death. From everything Iv seen on here as well as other forums they seem to suck ass. Only good thing is the reverse. Everyone says it’s a toss up between GTR and MB. Definitely want EFI and reverse i know both offer those. Motor will be going on a 15’ or 16’ havoc boat. Any help is appreciated!!!!! |
| Author: | brycecheramie [ Mon Jan 15, 2018 3:56 pm ] |
| Post subject: | Re: Motor decisions |
idk where you got that the boss sucked ass. The word is that they are just slower than the rest. Don't quote me, but I think willet said the boss picked up some speed once it was run for a while. why not go with a mudbuddy hdr, or GTR, or a PD? All have reverse. |
| Author: | Russ [ Mon Jan 15, 2018 3:58 pm ] |
On a boat that short, definitely check the weights. The less you put on the back the happier you'll be. All of those are heavier than your 45 mag. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | Brokeknee [ Mon Jan 15, 2018 9:11 pm ] |
Doesn't matter what brand motor you get, you put a load inside a 15ft havoc and they will all suck. |
| Author: | Greenhead69 [ Mon Jan 15, 2018 9:34 pm ] |
Thanks guys! Will most likely go with the new 37XD GTR on a 16’ havoc! Does anyone know what speeds a set up like that is running? My set up now pushes 33-34 with just me. 29-31 loaded down. I’d like to keep the speed ( not that i do much racing to the holes ) but still like to stay low 30’s |
| Author: | bluesky2012 [ Mon Jan 15, 2018 10:48 pm ] |
I'd guess between 22-24mph loaded down with a 2-3 man load. Maybe a hair more if you pack heavily. Youre losing hp going to a GTR37 because it is a stock rig. You won't get the same speeds. Sent from my iPhone using Tapatalk Pro |
| Author: | kib876 [ Tue Jan 16, 2018 5:11 am ] |
I could be wrong, but the 37efi will probably be about the same as a 45mag. When Efi was 1st coming out, it was said the Efi was equivalent to a carb Stage 1. Also the 45mag is mass produced BPS mods (not exactly sure what mods they have) but it isn't going to perform the same as "custom" mods |
| Author: | brycecheramie [ Tue Jan 16, 2018 6:36 am ] |
I'd say about 29-30 empty boat, 24-26 loaded. I'd also say you choice in motor is a good choice, but choice in boat, hmmmm, not so great. |
| Author: | Russ [ Tue Jan 16, 2018 6:54 am ] |
| Author: | Greenhead69 [ Tue Jan 16, 2018 7:52 am ] |
Does anyone know the prices for each stage of delta on this motor ? |
| Author: | Greenhead69 [ Tue Jan 16, 2018 7:54 am ] |
And what’s so bad about the havoc ?? |
| Author: | MaXXis85 [ Tue Jan 16, 2018 8:50 am ] |
| Author: | pokey79 [ Tue Jan 16, 2018 10:06 am ] |
and going with a 35 or higher u want to at least go to a 17' boat. |
| Author: | CypressCritter [ Tue Jan 16, 2018 10:15 am ] |
Short boat, heavy motor not a good combo. |
| Author: | Russ [ Tue Jan 16, 2018 10:35 am ] |
If you go 16ft, at least get something 54" or wider. My dad's boat is a 1652. It isn't bad, but could stand to be a little wider with the 35 on the back. My 1748 with 30ish hp on the back carried a 3man and gear load just as good as his did with a stock 35. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | Brokeknee [ Tue Jan 16, 2018 11:13 am ] |
| Author: | kib876 [ Tue Jan 16, 2018 11:23 am ] |
| Author: | bluesky2012 [ Tue Jan 16, 2018 2:59 pm ] |
| Author: | CypressCritter [ Wed Jan 17, 2018 9:11 am ] |
| Author: | BlueShamu [ Wed Jan 17, 2018 2:05 pm ] |
Here's why you don't want a Havoc. https://youtu.be/0VAEowFOajs Sent from my iPhone using Tapatalk |
| Author: | Greenhead69 [ Wed Jan 17, 2018 5:20 pm ] |
Anyone know how to get a hold of delta. Won’t answer phone or every number is wrong number |
| Author: | Brokeknee [ Wed Jan 17, 2018 6:40 pm ] |
Keep calling, their busy and will answer eventually. |
