It is currently Sat Mar 21, 2026 9:02 pm
Reply to topic  [ 7 posts ]
 Need help with a clutch issue on a GTR
Post Need help with a clutch issue on a GTR
This past Saturday I snapped the belt on my GTR (manual reverse). Being the smart one I am I thought you had to remove the clutch and the lower unit to replace the belt (stupid I know). So I got the belt on and everything put back together. When I crank the motor the prop begins to spin as it would if it were in gear at idol speed. So my question is, what have I done wrong to cause the motor to act like it’s in gear when it isn’t? The clutch still engages but it is useless because the belt is already turning at a speed that would would when normally in gear.
Any help is greatly appriciated
Wed Jan 17, 2018 8:57 pm
Post Re: Need help with a clutch issue on a GTR
Is the belt tension good? Typically a spinning prop is thick oil (cold oil) in planetary and not enough grease in the LU
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Thu Jan 18, 2018 8:44 am
Yes, the belt tension is good. And it is spinning a lot faster than that. You can’t stop the spin with a 2x4 like you could when it’s just free spinning.
Thu Jan 18, 2018 9:03 am
check to see if the armature disc is rubbing the rotor.
Bayou Surface Drive
337-351-0362
Thu Jan 18, 2018 9:42 am
What is the armature disc?
Thu Jan 18, 2018 11:19 am
Correct Clutch installed?
Short vs Long.... I had the incorrect sent to me once....
Kool-Aid Brigade
www.southernfowler.com
Thu Jan 18, 2018 11:40 am
ALSO.... did you put the little spacer between the crank and the clutch magnet?
Bayou Surface Drive
337-351-0362
Thu Jan 18, 2018 1:12 pm
