It is currently Fri Mar 29, 2024 12:23 am
[ 3 posts ] |
Aranesthesia
New Member
Pro drive engine trouble
Engine was running fine until we hit a log then motor dies out ... engine will turn over but no spark and EFI isn’t turning on with initial turn of the key ? All fuses (3) and relays (2) have been changed. Kill switch has been disconnected and jumped without making any difference. Any other ideas? Has to be something simple ... no noticeable wires are lose.
Fri Jan 26, 2018 4:57 pm |
MaXXis85
Re: Pro drive engine trouble
new model with CEL? if so get the blink codes key on-off-on-off-on within 5 seconds (leave on) CEL will blink 10* for 0, and number of blink for corresponding number. if it blinks 6*1 no codes present.
Mon Jan 29, 2018 2:48 pm |
Kruschpa
My 2015 37 EFI wire harness began to fail this past November at 160hrs. Replaced under warranty. Similar symptoms but was able to get back with fuel pump jumpered.
Thu Feb 01, 2018 7:44 pm |
[ 3 posts ] |
Users browsing this forum: No registered users and 242 guests |
