| 23hp Briggs won’t run with load added to it http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=72063 |
| Author: | Gunnar3232 [ Wed Feb 14, 2018 4:54 pm ] |
| Post subject: | 23hp Briggs won’t run with load added to it |
Need help. Mud buddy 23 runs great out of the water, but as soon as I dip the prop in the water it only idles then eventually sputters and dies. I have replaced the carb, spark plugs, checked all of the wire connections, And about everything j know to do. I thought the rev limiter might have been the problem, but I took it off, and same outcome. I got the rev limiter wet at one point and I figured that was the problem. Just wondering if maybe I shorted out the circuit breaker or something. Just need some help. Thanks!! |
| Author: | flint87 [ Wed Feb 14, 2018 7:00 pm ] |
| Post subject: | Re: 23hp Briggs won’t run with load added to it |
I can go ahead and tell you what everyone’s gona say. Check your compression and do a leak down test and go from there. Sent from my iPhone using Tapatalk |
| Author: | Russ [ Wed Feb 14, 2018 7:04 pm ] |
That sounds like it's a fuel problem. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | Gunnar3232 [ Wed Feb 14, 2018 7:22 pm ] |
Just checked and figured out I’m only running on one cylinder |
