It is currently Sat Mar 21, 2026 10:16 am
Reply to topic  [ 3 posts ]
 Piston Rings
Post Piston Rings
If your Piston rings are worn and causing blowby, would you need to replace the entire block or can you replace just the rings?
Tue Feb 27, 2018 2:13 pm
Post Re: Piston Rings
You should be able hone the cylinder and install new rings.
If the cylinder has wear you can bore it out and go to the next size up piston. (Shouldn't need a new block)
1848 DeadFowl pushed by a Stage 4 Delta powered MB HDR (JBP dusting)
Tue Feb 27, 2018 2:18 pm
Hone, bore check, GAP rings.
Wed Feb 28, 2018 9:28 am
