Pd 37 higher idle and sputtering
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=72169
Author:  woodie_slayer [ Mon Mar 05, 2018 12:19 am ]
Post subject:  Pd 37 higher idle and sputtering
My pd 37 was acting weird when my idle earlier was around 850-900rpms then after cranking up 2hrs later it randomly increased to 1060-1080rpms and wouldn't decrease.Then after that,i put it in gear and it sputtered the whole time with the throttle wide open .So i turned it off for 5 mins and it went away.Has anyone had this happen or have a clue whats going on?
Author:  Will C [ Mon Mar 05, 2018 9:10 am ]
Post subject:  Re: Pd 37 higher idle and sputtering
Check engine light blinking at you?
Author:  woodie_slayer [ Mon Mar 05, 2018 9:17 am ]
Its not the updated efi
Author:  Will C [ Mon Mar 05, 2018 9:56 am ]
It would be nice if a shop in your area can check the ecu for codes. Aside from that clean and tighten ground and power wires at engine and at battery
Author:  woodie_slayer [ Mon Mar 05, 2018 10:07 am ]
Ok will do.does it sound like a surge somewhere to you Will? This thing had me dumbfounded yesterday,thankfully the fish were biting 400yds off haha.
Author:  MaXXis85 [ Mon Mar 05, 2018 11:04 am ]
Also I have seen mis adjusted TPS sensors, but it sounds like a simple connection issue.
Author:  woodie_slayer [ Wed Mar 07, 2018 7:01 pm ]
Alright fellas I found out what it was the hard way.it was the ground to the battery and it burned the crap out of me.thank y'all for helping out,I appreciate it.
Author:  Will C [ Thu Mar 08, 2018 1:31 am ]
Easy fix,,, good deal
