It is currently Mon Nov 16, 2026 4:30 am
Reply to topic  [ 1 post ]
 Prodrive 36hp sporadic bog
Post Prodrive 36hp sporadic bog
I’ve got an 06 PD 36hp with heads,hsr42,bps Q. While running WOT if I hit something and kick the motor up it will die until I bring it back under half throttle. Same issue will arise every now and again just running around the lake. It’s very random and I haven’t been able to predict it yet. Brand new new fuel tank,line,filter,bulb, fuel pump. Carb and heads are only 3 months old but it has this problem before that’s why I modded it thinking it would fix it. Sometimes pumping primer bulb will help slowly but it keeps the filter full. I’ve checked all wiring/connections and can’t find anything obvious wrong. Anybody else run into this issue or does it sound electrical related and maybe I need to keep looking in that area?
Wed Mar 14, 2018 9:40 am
