It is currently Fri Aug 21, 2026 6:43 pm
Reply to topic  [ 4 posts ]
 Crankshaft dimensions
Post Crankshaft dimensions
I’ve been searching and can’t seem to find the dimensions for the crankshaft on a Mudbuddy 45mag. I seem to remember seeing somewhere that the crank on a Mudbuddy is 1 1/8X3” but can’t verify that and I don’t want to tear mine apart to see. I’m going to start a build on a second power head and have a donor 35 available but the crank is 1 3/8X4”. The donor engine is cheap enough that replacing the crank wouldn’t be an issue. Thanks for any help guys.
Wed Mar 28, 2018 8:40 pm
Post Re: Crankshaft dimensions
4", 1 1/8" I believe.
#TheGhostBoat
Wed Mar 28, 2018 8:42 pm
Thanks, Russ. Do you know if changing out the crank is as simple as just swapping it for one with the correct PTO dimensions?
Wed Mar 28, 2018 9:02 pm
Should be.
#TheGhostBoat
Thu Mar 29, 2018 6:43 am
