It is currently Fri Aug 21, 2026 4:04 pm
Reply to topic  [ 11 posts ]
 2009 Prodrive
Post 2009 Prodrive
I have a 2009 prodrive that is turning over but isn't starting. Im no mechanic but the inline fuel filter is good. I changed the spark plugs and appear to be firing. Not sure what the problem is. Any insight is appreciated.
Thanks
Chauncey
18x48 Brother Breaux Bateaux with 36 PD automatic everything!!
Wed Mar 28, 2018 11:53 am
Post Re: 2009 Prodrive
Wed Mar 28, 2018 11:58 am
The basic spark plug evaluation. Removal and ground to engine.
Wed Mar 28, 2018 12:02 pm
Wed Mar 28, 2018 12:14 pm
I removed the hose from the carb to the fuel pump, no sign of gas coming through when starting the engine.
Wed Mar 28, 2018 2:21 pm
Wed Mar 28, 2018 2:23 pm
Im going to replace it. Ill let you know.
Appreciate it!
Wed Mar 28, 2018 2:24 pm
Wed Mar 28, 2018 2:37 pm
Took off fuel and brought it to a small engine/tractor store. The pump was pumping fuel, the guy said its not the pump. Could it be the kill switch-cleaned ground. Is there a way to bypass it?
Wed Mar 28, 2018 4:26 pm
If you had your fuel like hooked up to your fuel pump and you turned your key to start your motor and fuel didn’t come out th fuel pump, then you have an air leak in your fuel line, or pump is no good.
Wed Mar 28, 2018 4:51 pm
Hopefully, i will be able to find a new fuel pump in the am.
Wed Mar 28, 2018 5:31 pm
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 1 guest
