It is currently Wed Apr 24, 2024 2:15 pm
[ 8 posts ] |
duckrunner99
Joined: Sat Oct 26, 2013 1:00 pm Posts: 340 Location: Wisconsin
37efi mod questions
So I have a stock mudbuddy 37efi with just a voodoo exuahst and lets just say I want more. so I have a 5500 block that’s sitting with all the mods and my question is Can I strip anything off of that to get a good safe power increase also what else would I need to wrap it all up to make it work
Mon Apr 23, 2018 8:42 pm |
Will C
Re: 37efi mod questions
What parts are you thinking of swapping? Yes the parts will transfer over. It will need to be tuned
Tue Apr 24, 2018 8:10 am |
duckrunner99
Wed Apr 25, 2018 8:06 am |
Will C
Didn't know if your 5500 was a mag or not. Aside from whatever parts you use you will need to weld an o2 bung into your header, get a wideband sensor setup, and get a controller. Controller options are the Dobec or call glade at bps and see if he can fix u up. If you do the heads and rockers only I bet the bps tuner for the 4400 will be close.
Wed Apr 25, 2018 9:25 am |
Glade
First thing first, is it a 55 mag, or black death?
If it is a mag, you can use your heads, rockers, pushrods, pistons, c-rods, and cam.
I sell a tuner that is already set up for those parts. All you have to do is plug it in, and turn the dial to the 3 position. No o2 bung necessary. Your current exhaust is different than what I used to build the fuel map, so you may have to do some fine tuning with the low, mid, and high rpm dials on the tuner. This can be done by reading spark plugs.
Wed Apr 25, 2018 10:03 am |
duckrunner99
Wed Apr 25, 2018 3:04 pm |
brycecheramie
Thu Apr 26, 2018 9:13 am |
schmitt
Joined: Fri Jun 25, 2010 3:33 pm Posts: 1177 Location: WI
_________________ 1848 DeadFowl pushed by a Stage 4 Delta powered MB HDR (JBP dusting)
Mon May 14, 2018 9:19 pm |
[ 8 posts ] |
Users browsing this forum: Majestic-12 [Bot], Rickman and 234 guests |
