apine1187
 2014 GTR 35 losing power
I am looking for some suggestions, my GTR 35 has 200 hrs and for some reason struggles to get up on plane with light load. RPM’s out of the water seem fine but under a load i can only get 3,100. Any help wohld be appreciated .
| Sun Apr 29, 2018 3:20 am |
brycecheramie
 Re: 2014 GTR 35 losing power
| Sun Apr 29, 2018 5:30 am |
Woodiebuster
Valves could definitely be the culprit, not a bad idea to check them periodically. It could be a number of things though. Swap your fuel with good fuel and run some sea foam through it. Also check for air leaks or leaks in the fuel line.
| Sun Apr 29, 2018 10:17 am |
bluesky2012
Yeah I'm voting either valve lash or valve leakage. Get a leakdown done. Might be time to get the heads worked.
| Sun Apr 29, 2018 4:27 pm |
DmaxHunter
Joined: Wed Jan 18, 2012 7:21 pm Posts: 2207 Location: North Alabama
_________________ 2014 PRODIGY 1754 (#19) 2014 5500 BAMF HDR RETRO SOLD
| Sun Apr 29, 2018 5:16 pm |
bluesky2012
| Sun Apr 29, 2018 6:28 pm |
DmaxHunter
| Sun Apr 29, 2018 7:02 pm |
bluesky2012
| Mon Apr 30, 2018 5:20 am |
apine1187
I did have compression checked and both sides were good, changing plugs next then going to check valve lash. What are thoughts on timing?
| Tue May 01, 2018 5:08 am |
Russ
It's fine. Check valve lash first, and when you say good, what was the compression?
| Tue May 01, 2018 6:08 am |
bluesky2012
Good compression doesn't mean you don't have valve leakage
| Tue May 01, 2018 7:00 am |
KJH
Joined: Tue Jun 09, 2009 9:09 pm Posts: 520 Location: Nebraska
How do you check for valve lash and leakage? Is this something that's easy to do?
_________________ 1854 Brother Breaux and Boss 40XP and 90hp outboard.
| Thu Aug 16, 2018 12:34 pm |
bluesky2012
Get a set of feeler gauges at autozone for $6 then follow this Valve lash: https://youtu.be/mH73IdavxzILeak down will require a leak down tester. May want to just go to a local Engine repair shop and pay them like $60 to do that quickly for you. Sent from my iPhone using Tapatalk Pro
| Thu Aug 16, 2018 12:44 pm |
KJH
Awesome. Thanks.
| Thu Aug 16, 2018 1:03 pm |
MaXXis85
Ill put money on 20-40% leakage from the intake valves
| Thu Aug 16, 2018 5:04 pm |
kirk
Joined: Thu Apr 18, 2013 5:52 pm Posts: 870 Location: SW LA
| Thu Aug 16, 2018 7:21 pm |
MaXXis85
| Fri Aug 17, 2018 9:13 am |
