It is currently Tue Apr 16, 2024 3:34 pm
Reply to topic  [ 17 posts ]
 2014 GTR 35 losing power
Post 2014 GTR 35 losing power
I am looking for some suggestions, my GTR 35 has 200 hrs and for some reason struggles to get up on plane with light load. RPM’s out of the water seem fine but under a load i can only get 3,100. Any help wohld be appreciated .
Sun Apr 29, 2018 3:20 am
Post Re: 2014 GTR 35 losing power
Sun Apr 29, 2018 5:30 am
Valves could definitely be the culprit, not a bad idea to check them periodically.
It could be a number of things though.
Swap your fuel with good fuel and run some sea foam through it.
Also check for air leaks or leaks in the fuel line.
Sun Apr 29, 2018 10:17 am
Yeah I'm voting either valve lash or valve leakage. Get a leakdown done. Might be time to get the heads worked.
Sun Apr 29, 2018 4:27 pm
Sun Apr 29, 2018 5:16 pm
Sun Apr 29, 2018 6:28 pm
Sun Apr 29, 2018 7:02 pm
Mon Apr 30, 2018 5:20 am
I did have compression checked and both sides were good, changing plugs next then going to check valve lash. What are thoughts on timing?
Tue May 01, 2018 5:08 am
It's fine. Check valve lash first, and when you say good, what was the compression?
#TheGhostBoat
Tue May 01, 2018 6:08 am
Good compression doesn't mean you don't have valve leakage
Tue May 01, 2018 7:00 am
How do you check for valve lash and leakage? Is this something that's easy to do?
1854 Brother Breaux and Boss 40XP and 90hp outboard.
Thu Aug 16, 2018 12:34 pm
Get a set of feeler gauges at autozone for $6 then follow this Valve lash: https://youtu.be/mH73IdavxzI
Leak down will require a leak down tester. May want to just go to a local Engine repair shop and pay them like $60 to do that quickly for you.
Thu Aug 16, 2018 12:44 pm
Awesome. Thanks.
Thu Aug 16, 2018 1:03 pm
Ill put money on 20-40% leakage from the intake valves
Thu Aug 16, 2018 5:04 pm
Thu Aug 16, 2018 7:21 pm
Fri Aug 17, 2018 9:13 am
Users browsing this forum: No registered users and 120 guests
