It is currently Sat Aug 22, 2026 10:17 pm
Reply to topic  [ 3 posts ]
 Crankcase cover where to buy
Post Crankcase cover where to buy
Started with a snapped crank case bolt then while disassembling to drill out bolt noticed my cover is cracked. Where is the best place and price to get a new case cover, gasket, new bolts and oil filter o rings. It’s for a 35 gtr. Thanks for any help.
Tue May 08, 2018 8:01 am
Post Re: Crankcase cover where to buy
I got mine from the guys at delta. I sent my timing gear in to be machined down so I wouldn’t have to use the gasket. Sealed it all back up with grey permatex. Can’t remember how much it was but it was great dealing with delta.
Tue May 08, 2018 8:37 am
any briggs dealer can get you one. Unfortunately that happened from the bolts loosening up and letting it leak too long. I see it quite often. A cover is approx. $250. I agree on machining the parts for a gasketless repair.
Tue May 08, 2018 1:21 pm
