| Best oil??? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=72482 |
| Author: | Greentop69 [ Sat May 19, 2018 9:46 am ] |
| Post subject: | Best oil??? |
What is the best weight of oil for these motors? Read something where synthetic 5w-30 is good for -20 too 100 Degrees. Can you run Royal Purple in these engines? Was leaning towards the synthetic high performance royal Purple or the amsoil? Any thoughts? |
| Author: | Russ [ Sat May 19, 2018 10:51 am ] |
| Post subject: | Re: Best oil??? |
3 in 1 is best. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | DmaxHunter [ Sat May 19, 2018 12:54 pm ] |
I run Amsoil 4t Briggs Approved oil for cart racing. It is a little high think 8 or 9 bucks a quart with preferred membership. However, remember it just a lawn mower engine, but again to each their own. |
| Author: | Roostertail3 [ Sat May 19, 2018 3:54 pm ] |
Briggs says 5-30 has the widest temp ranges. You can run royal purple, it's expensive, but there are others just as good for much cheaper. I would get any decent 5-30 and not think twice about it. My gravely lawnmower gets motor craft and I've never had an issue. |
| Author: | Bigbend [ Sat May 19, 2018 9:38 pm ] |
5W-30, whatever brand puts your mind at ease. Ton more to worry about with these Briggs than the oil brand. |
| Author: | Wchauvin [ Sun May 20, 2018 12:23 am ] |
Anybody running 10w-40 synthetic? That's what I run in south Louisiana because in the summer, it gets stupid hot. |
| Author: | DENNYEDWARDS [ Sun May 20, 2018 5:07 am ] |
15 W 40 Rotella since new. 200+ hrs on it with no oil related issues. |
| Author: | boatguy [ Sun May 20, 2018 6:58 am ] |
I use Mobil 1 5w-30 never had a prob. But I do have an additive question.... Did a search and came up with nothing... sooo.. Does anyone have any experience or use the "HotShot's" FR3 Friction Reducer oil additive? Does anyone use this in their mudmotors... I few of my buddies use it in their diesel trucks and gas trucks as well.... they swear by it...???? |
| Author: | libertarian [ Tue May 29, 2018 10:47 am ] |
Shell Rotella T6 Synthetic 5w-40 because it gets stupid hot in Texas too. I use it in everything..mowers, generators, etc. I don't use any additives because I'm not a chemist. Most engine manufacturers advise no additives, of course they're selling engines not additives. There's always a new miracle additive coming along every few years, then disappears. If it was as good as they claimed, one of the oil companies would use it and have one heck of advantage. |
| Author: | Russ [ Tue May 29, 2018 11:21 am ] |
This question comes up, in various forms, fairly regularly. Briggs doesn't want to deal with warranty issues, and doesn't want to lose customers. They recommend an oil. It's been proven a stock Briggs will hit 2k hours on that oil with regular oil changes. Why reinvent the wheel? If you're running more rpms than it's designed around because of mods, then run a high zinc oil that's been proven to work with these types of engines. The amsoil (don't remember which one), rotella (I think it's the t6 that has it), valvoline vr1 all have a decent zinc package if you want to spend more on oil. Stop over thinking it. A tiny fraction of these things has ever failed because of choice of oil, and it was likely because it was just too thick in the cold one too many times and that guy had always run thicker oil in his vehicles and ignored the manufacturer's recommendation. Typically, a failure due to oil is due to just not changing it or the oil pump dying (which shouldn't be a worry). #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | brycecheramie [ Tue May 29, 2018 2:57 pm ] |
| Author: | Will C [ Tue May 29, 2018 8:27 pm ] |
Even the Briggs oil has an older style api and more zinc then most because it's not an automotive oil. |
| Author: | MaXXis85 [ Thu May 31, 2018 7:44 am ] |
2 quarts of any oil is better than no oil. |
| Author: | DmaxHunter [ Thu May 31, 2018 7:50 am ] |
Russ Its Amsoil Z Rod that has the high zinc Sent from my SM-N950U using Tapatalk |
| Author: | MaXXis85 [ Fri Jun 01, 2018 5:22 am ] |
| Author: | deucem [ Fri Jun 01, 2018 9:05 am ] |
I am currently running Amsoil signature series 5W-30, since it has a wide temp range and it gets really cold up here. I have had good luck with it. Since I am cracking my case and adding a cam, I figured that I would switch to the Amsoil 4T. I looked at a few older threads and based on Amsoil description for intended use and my discussion with their Tech team, it should good fit. Yeah its pricy, but isn't this whole damn game...yeah...its a lawnmower engine, but why not roll with the best. To each their own. |
| Author: | Will C [ Fri Jun 01, 2018 9:14 am ] |
Errbody says it's just a lawnmower until it's time to fix it, then folks realize how much parts are for these toys. The 2 oils I keep in stock are zrod and vr1. I use zrod in most engines unless a customer says they want to be able to buy their oil locally then I use vr1. Both have been good to me over the years |
| Author: | ronbow [ Fri Jun 01, 2018 6:36 pm ] |
Amsoil or Rotela says Ronbow |
| Author: | Russ [ Fri Jun 01, 2018 7:10 pm ] |
| Author: | Will C [ Fri Jun 01, 2018 8:54 pm ] |
My starter works |
| Author: | Russ [ Fri Jun 01, 2018 9:57 pm ] |
So, yeah...about that.... Lol #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | DmaxHunter [ Sun Jun 03, 2018 5:24 am ] |
| Author: | deucem [ Fri Jun 29, 2018 10:24 am ] |
Amsoil 4T zinc content is 1537 ppm per the email I just got from their rep. That is higher than the ZRod product, if I remember correctly. |
| Author: | cb5331 [ Fri Jun 29, 2018 9:00 pm ] |
| Author: | BlueShamu [ Fri Jun 29, 2018 9:30 pm ] |
I run my lawnmower WOT with fish oil in the crankcase....and have better luck than I do with a mudmotor running the high end, royal zinc, high synthetic, purple weight stuff. |
| Author: | GDLT31 [ Sat Jun 30, 2018 10:15 pm ] |
Ok, I have a GDLT31 and I’m running Mobil 1 10W30 and was wondering if I switched Rotella T6 10W30 if would hurt anything by switching.Reason I ran into a tractor dealer switching out to another brand.And I can buy eleven quart cases really cheap.Any thoughts? |
| Author: | BlueShamu [ Sun Jul 01, 2018 8:42 am ] |
You are entirely overthinking this..... Buy it. |
| Author: | GDLT31 [ Sun Jul 01, 2018 11:45 pm ] |
I pick up the oil Monday,oh it’s 10 1/2 cases. I won’t tell the price but dirt cheap.Thanks for the encouragement. |
