| What are the benefits of lower hp if price isn’t an issue an http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=72565 |
| Author: | Plandr5 [ Sun Jun 10, 2018 9:56 pm ] |
| Post subject: | What are the benefits of lower hp if price isn’t an issue an |
I’m looking at getting a gatortail. Outside of price what would be the benefit of a 35 hp over the 40? I believe the 35,37,and 40 all weigh the same and I understand what I can afford but would there be a time when you can argue it’s simply too much motor in terms of hp? Dropping it on a 16x48 gatortail with a timber deck so 17x48 overall. Sent from my iPhone using Tapatalk |
| Author: | Will C [ Sun Jun 10, 2018 10:11 pm ] |
| Post subject: | Re: What are the benefits of lower hp if price isn’t an issu |
As far as hp don't think the 40 would ever feel like too much hp. I would say the the only advantage to a 35 is that it's still a carb motor . For the man that wants to wrench on it himself the carb motor is the most straight forward. |
| Author: | kib876 [ Mon Jun 11, 2018 2:39 am ] |
If I’m not mistaken, a gator tail 16x48 will be a 16x48 even with hunt duck. They don’t add to the length like gator-Trax |
| Author: | Koondog62 [ Mon Jun 11, 2018 3:16 am ] |
| Author: | Swampin [ Mon Jun 11, 2018 6:21 am ] |
[beliewould there be a time when you can argue it’s simply too much motor in terms of hp? Dropping it on a 16xf48 Sent from my iPhone using Tapatalk[/quote] IMO NO! You won’t have too much HP |
| Author: | DENNYEDWARDS [ Mon Jun 11, 2018 10:22 am ] |
Terms of boat handling HP you should be ok with the 40 hp on a 1648. I run a moded MB 45 on a 1648 hull with no problems. |
| Author: | Plandr5 [ Mon Jun 11, 2018 5:26 pm ] |
I thought the same. I saw the original invoice and they called it 16 though it’s 17 tail to tip and wlf registration lists it as 17 Sent from my iPhone using Tapatalk |
| Author: | Plandr5 [ Mon Jun 11, 2018 5:30 pm ] |
[quote="Swampin"][beliewould there be a time when you can argue it’s simply too much motor in terms of hp? Dropping it on a 16xf48 Sent from my iPhone using Tapatalk |
| Author: | banded-mallard [ Thu Jun 14, 2018 4:32 am ] |
The main benefit of lower HP motors is "IF" you hunt WMA HP restricted areas. I know CLF is strick on modded motors. Not even aftermarket exhaust. |
| Author: | kirk [ Thu Jun 14, 2018 5:44 am ] |
| Author: | jc [ Thu Jun 14, 2018 5:29 pm ] |
No such thing as too much hp. Just decide if you want a carb or efi. You can always modify either. |
