| Crankcase cover dowel pins http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=72566 |
| Author: | jc [ Mon Jun 11, 2018 4:11 pm ] |
| Post subject: | Crankcase cover dowel pins |
Some how I have lost the 2 dowel pins on my crankcase and I need 2 more. I can't find the part number. Can anyone help? |
| Author: | DmaxHunter [ Mon Jun 11, 2018 8:58 pm ] |
| Post subject: | Re: Crankcase cover dowel pins |
I have a extra set never used, give you a good deal on them. I believe this is the part number 846324. STUD Sent from my SM-N950U using Tapatalk |
| Author: | MaXXis85 [ Tue Jun 12, 2018 7:09 am ] |
Call BPS |
| Author: | 50fps [ Tue Jun 12, 2018 8:28 am ] |
If I remember correctly the ones used on the cyl deck also fit the sump. 718A 809508 |
| Author: | MaXXis85 [ Tue Jun 12, 2018 11:43 am ] |
| Author: | DmaxHunter [ Tue Jun 12, 2018 7:14 pm ] |
He are the pto case sleeves, I don't have extra head sleeves. We just pulled heads off my bodies rig, when I put them back on I'll compare. Sent from my SM-N950U using Tapatalk |
| Author: | 50fps [ Tue Jun 12, 2018 7:58 pm ] |
| Author: | DmaxHunter [ Wed Jun 13, 2018 11:50 am ] |
Mine did not come with any either. I studded my motor and recieved two of these, along with the studs, but with half machined down. For some reason the case hole is slightly smaller than block. If I recall correctly, trying to find the other set. I have the dowel pin above oil ports model. Yet, briggs still sells these? Don't know why they do not come installed to begin with. Sent from my SM-N950U using Tapatalk |
| Author: | MaXXis85 [ Wed Jun 13, 2018 1:29 pm ] |
| Author: | jc [ Wed Jun 13, 2018 6:33 pm ] |
Thanks for the replies |
