jc
 Crankcase cover dowel pins
Some how I have lost the 2 dowel pins on my crankcase and I need 2 more. I can't find the part number. Can anyone help?
| Mon Jun 11, 2018 4:11 pm |
DmaxHunter
Joined: Wed Jan 18, 2012 7:21 pm Posts: 2207 Location: North Alabama
 Re: Crankcase cover dowel pins
I have a extra set never used, give you a good deal on them. I believe this is the part number 846324. STUD Sent from my SM-N950U using Tapatalk
_________________ 2014 PRODIGY 1754 (#19) 2014 5500 BAMF HDR RETRO SOLD
| Mon Jun 11, 2018 8:58 pm |
MaXXis85
Call BPS
| Tue Jun 12, 2018 7:09 am |
50fps
If I remember correctly the ones used on the cyl deck also fit the sump.
718A
809508
| Tue Jun 12, 2018 8:28 am |
MaXXis85
| Tue Jun 12, 2018 11:43 am |
DmaxHunter
He are the pto case sleeves, I don't have extra head sleeves. We just pulled heads off my bodies rig, when I put them back on I'll compare.
| Tue Jun 12, 2018 7:14 pm |
50fps
| Tue Jun 12, 2018 7:58 pm |
DmaxHunter
Mine did not come with any either. I studded my motor and recieved two of these, along with the studs, but with half machined down. For some reason the case hole is slightly smaller than block. If I recall correctly, trying to find the other set. I have the dowel pin above oil ports model. Yet, briggs still sells these? Don't know why they do not come installed to begin with.
| Wed Jun 13, 2018 11:50 am |
MaXXis85
| Wed Jun 13, 2018 1:29 pm |
jc
Thanks for the replies
| Wed Jun 13, 2018 6:33 pm |
