It is currently Fri Mar 20, 2026 12:56 pm
Reply to topic  [ 10 posts ]
 Crankcase cover dowel pins
Post Crankcase cover dowel pins
Some how I have lost the 2 dowel pins on my crankcase and I need 2 more. I can't find the part number. Can anyone help?
Mon Jun 11, 2018 4:11 pm
Post Re: Crankcase cover dowel pins
I have a extra set never used, give you a good deal on them. I believe this is the part number
846324. STUD
Sent from my SM-N950U using Tapatalk
Mon Jun 11, 2018 8:58 pm
Call BPS
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Tue Jun 12, 2018 7:09 am
If I remember correctly the ones used on the cyl deck also fit the sump.
718A
809508
Tue Jun 12, 2018 8:28 am
Bayou Surface Drive
337-351-0362
Tue Jun 12, 2018 11:43 am
He are the pto case sleeves, I don't have extra head sleeves. We just pulled heads off my bodies rig, when I put them back on I'll compare.
Tue Jun 12, 2018 7:14 pm
Tue Jun 12, 2018 7:58 pm
Mine did not come with any either. I studded my motor and recieved two of these, along with the studs, but with half machined down. For some reason the case hole is slightly smaller than block. If I recall correctly, trying to find the other set. I have the dowel pin above oil ports model. Yet, briggs still sells these? Don't know why they do not come installed to begin with.
Wed Jun 13, 2018 11:50 am
Bayou Surface Drive
337-351-0362
Wed Jun 13, 2018 1:29 pm
Thanks for the replies
Wed Jun 13, 2018 6:33 pm
cron
