It is currently Fri Mar 20, 2026 9:36 am
Reply to topic  [ 9 posts ]
 Need guidance on idle.
Post Need guidance on idle.
Motor is a 2011 35hp gdsd. I have had my valve lash checked/adjusted and carb cleaned adjusted. Had trouble with idling before having work done. Had it “fixed” and after 1 trip it’s back to not idling. Give it a little gas and it’s fine but let off the throttle
And it jumps down to 6-700 rpm and slowly falls till dying. Should I just adjust the idle screw or mess with the governed idle spring .
Sun Jun 17, 2018 7:41 pm
Post Re: Need guidance on idle.
Stock carb ???
If yes - do you still have an idle spring - or has it been lost ???
Sun Jun 17, 2018 8:15 pm
Every stock 35 I had did that
Sun Jun 17, 2018 9:06 pm
Adjust the idle to be at 1250 out of water, then adjust the air fuel mixture. Readjust the idle if necessary to 1250. Report back.
#TheGhostBoat
Sun Jun 17, 2018 9:43 pm
Mon Jun 18, 2018 2:45 pm
Mon Jun 18, 2018 2:52 pm
I’ve done 2 things to fix idle.
1. Pull the slack out of the throttle cable (1/4”-1/2”)
2. Turn idle screw. In my case no more than 1/4 turn. If you turn too much you’ll know it when you crank it up.
Mon Jun 18, 2018 8:14 pm
Adjust that screw while it's running after it's warmed some. Can't set to a specific rpm if you adjust it while it's off. Air mixture screws too. Can't see if they're correct without it running.
#TheGhostBoat
Mon Jun 18, 2018 8:24 pm
Adjust after it has warmed up, too.
Tue Jun 19, 2018 2:32 pm
