| Need guidance on idle. http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=72588 |
| Author: | deaddrake [ Sun Jun 17, 2018 7:41 pm ] |
| Post subject: | Need guidance on idle. |
Motor is a 2011 35hp gdsd. I have had my valve lash checked/adjusted and carb cleaned adjusted. Had trouble with idling before having work done. Had it “fixed” and after 1 trip it’s back to not idling. Give it a little gas and it’s fine but let off the throttle And it jumps down to 6-700 rpm and slowly falls till dying. Should I just adjust the idle screw or mess with the governed idle spring . |
| Author: | Gigafowl [ Sun Jun 17, 2018 8:15 pm ] |
| Post subject: | Re: Need guidance on idle. |
Stock carb ??? If yes - do you still have an idle spring - or has it been lost ??? |
| Author: | godvl [ Sun Jun 17, 2018 9:06 pm ] |
Every stock 35 I had did that |
| Author: | Russ [ Sun Jun 17, 2018 9:43 pm ] |
Adjust the idle to be at 1250 out of water, then adjust the air fuel mixture. Readjust the idle if necessary to 1250. Report back. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | deaddrake [ Mon Jun 18, 2018 2:45 pm ] |
| Author: | deaddrake [ Mon Jun 18, 2018 2:52 pm ] |
| Author: | kirk [ Mon Jun 18, 2018 8:14 pm ] |
I’ve done 2 things to fix idle. 1. Pull the slack out of the throttle cable (1/4”-1/2”) 2. Turn idle screw. In my case no more than 1/4 turn. If you turn too much you’ll know it when you crank it up. Sent from my iPad using Tapatalk |
| Author: | Russ [ Mon Jun 18, 2018 8:24 pm ] |
Adjust that screw while it's running after it's warmed some. Can't set to a specific rpm if you adjust it while it's off. Air mixture screws too. Can't see if they're correct without it running. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | BlueShamu [ Tue Jun 19, 2018 2:32 pm ] |
Adjust after it has warmed up, too. |
