It is currently Fri Mar 20, 2026 3:08 pm
Reply to topic  [ 4 posts ]
 37EFI Vanguard won’t idle
Post 37EFI Vanguard won’t idle
The motor won’t start unless you hold the throttle wide open. When it does start it seems like it’s flooding It runs really rough enough to shake the boat on the trailer. I checked both spark plugs and have good spark. I pulled the fuel filters and pumps apart and there is good fuel going to the injection. I haven’t tried pulling the injectors. Has anyone had this problem?
Sat Jun 23, 2018 5:45 pm
Post Re: 37EFI Vanguard won’t idle
Inspect the pushrods and set the valves first
Sat Jun 23, 2018 9:01 pm
Yep, pull the valve covers, sounds like it may be running on one hole.
-Custom pool noodle
-stage 4 water wings
Sun Jun 24, 2018 8:22 am
Mon Jun 25, 2018 7:33 am
