It is currently Fri May 10, 2024 5:35 pm
[ 6 posts ] |
critch5
GTR losing rpms at WOT
Motor wth mikuni carb and guttted exhaust... (all I know for sure bought it that way)... will run like scalded dog for about 3-4 minutes then lose rpms slowly... can let off and go again and runs good for 3-4 minutes then loses rpms again... new fuel pump last night and filter... still doing it... can cruise on plane and won’t act up... only at WOT... water in fuel? Sucking air from tank... boat is 1651 excel with outboard tank in the front... try to run straight gasoline in it as much as possible ...boat does sit between uses for approximately 2 weeks... any help would be appreciated thanks
Sun Jun 24, 2018 10:29 am |
Buddyclub
Re: GTR losing rpms at WOT
Is the vent open on the gas tank?
Sun Jun 24, 2018 2:35 pm |
Wchauvin
I was about to ask the same question
Sun Jun 24, 2018 2:49 pm |
Tommyh172
Have usimiller problem, 36 Gd, surges , pops thru carb,13 Volts at carbaroter
Sun Jul 15, 2018 9:43 am |
jc
Check your fuel line. The marine line is bad about the inner liner separating and restricting the flow.
Sun Jul 15, 2018 6:05 pm |
Russ
Float needs adjusting in carb, air leak in the fuel line somewhere, issue with fuel line, fuel tank not vented well enough (loosen the cap next time you run it and see if that's it)
Sun Jul 15, 2018 6:16 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 177 guests |
