msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
 Diesel Generator Isuzu or Perkins
I'm putting the purchase on a new generator for my camp. I think I narrowed it down to either a Isuzu or Perkins engine. The generator will be the same on the two so I guess it's a preference. Hopefully some diesel mechanics can give me some feed back on which they would rather have and why. I don't really know anything about diesels so any help would be appreciated
Here are the engine specs.
Isuzu: Installation Data Model Isuzu 3CB Type Vertical In-Line, Indirect Injection Horsepower 14 HP Displacement 1.1 Liters Oil Capacity (w/ Oil Filter) Approx. 4.8 qts RPM 1800 Cylinders 3 Cylinder Block Cast Iron w/ Cast Iron Sleeves Bore & Stroke 3.05 x 3.14 in. Cooling Liquid-Cooling, pusher Fan Coolant Capacity Approx. 6.5 Qts Fuel No. 2 Diesel Electric Fuel Pump 12 V - Standard Cold Weather Starting Aid Glow Plugs Starting System Electric This brawny little three cylinder set has plenty of power to run your home, job site or business. This unit includes an Isuzu 3CB 3 cylinder 1800 RPM diesel engine, replaceable cylinder liners, brushless generator end, liquid cooling, muffler, cool flow radiator w/ fan guards (pushor fan), replaceable foam air filter element, steel channel base, automatic voltage regulation, fast-acting glow plugs for cold starting, auto shutdowns for low oil/high water temperature, turn-key electric start and is rated for over 30,000 hours use
Perkins model 403D-11G General Data Number of cylinders 3 Cylinder arrangement Vertical in-line Cycle 4 stroke Aspiration Naturally aspirated Combustion system Indirect injection Compression ratio 23:01 Bore and Stroke 77 x 81 mm Displacement 1.131 litres Direction of rotation Anti-clockwise viewed on flywheel Cooling system Water cooled Total coolant capacity 5.2 litres Total lubrication 4.9 litres system capacity Length 776 mm Width 449 mm Height 700 mm Total weight (dry) 129.2 kg
| Tue Dec 31, 2013 9:53 am |
lastchance
Joined: Wed Feb 09, 2011 1:56 pm Posts: 1646 Location: Chauvin
I'd go with Isuzu, Mitsubishi, Yanmar, or Kubota......... It's easier to find parts and they are readily available!
| Tue Dec 31, 2013 11:12 am |
msm8281
 Re: Diesel Generator Isuzu or Perkins
Im leaning toward the isuzu. I was just considering the perkins cause perkins is now owned by Cat.
| Tue Dec 31, 2013 11:58 am |
lastchance
| Tue Dec 31, 2013 12:13 pm |
msm8281
Thanks
| Tue Dec 31, 2013 12:26 pm |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
yep stay away from the perkins and get the Isuzu cause I watch the mechanic at work waiting and waiting for parts for the perkins equipment we have at work
| Tue Dec 31, 2013 12:49 pm |
Team Schmo
Joined: Sun Sep 08, 2013 8:05 pm Posts: 814 Location: Montana
Isuzu all the way we have 2 3cb for when power goes out.. Haven't had any issues yet.. You can't beat the warranty either..
_________________ You can't fix stupid
| Tue Dec 31, 2013 5:30 pm |
tchauvin
Joined: Wed Jul 13, 2011 6:23 pm Posts: 4898 Location: Bourg LA
Isuzu= The largest diesel manufacturer in the world! They are the ones GM reached out to for the design of the Duramax.
They know thier shit...
| Tue Dec 31, 2013 5:33 pm |
msm8281
Well it looks like I will go isuzu. Now I just have figure out where I will purchase it. Anyone have any suggestions?
| Tue Dec 31, 2013 5:42 pm |
Team Schmo
Try central Maine generators. Good prices and fast shipping...
| Tue Dec 31, 2013 5:58 pm |
Old School
Joined: Thu Dec 17, 2009 9:44 pm Posts: 3067 Location: Earth
There is a place in New Iberia….Electrical Innovators…..talk to Harry..He can get anything and any size .
_________________ Gator tail
| Tue Dec 31, 2013 6:08 pm |
msm8281
| Tue Dec 31, 2013 7:16 pm |
Team Schmo
| Tue Dec 31, 2013 7:27 pm |
Marshgoat
Get the Isuzu !!! We have a 13kw set with over 4000 hrs on it and not a single problem. Check out hardydiesel.com that's where we got ours. Much cheaper than anywhere else and shipping most times is free. Try to get one with a Newage or Marathon end on it. Stay away from the Chinese gen ends, they are junk.
| Fri Jan 03, 2014 9:28 am |
Starlight
Joined: Fri Jul 06, 2018 2:53 am Posts: 1 Location: China
I am a technician. Maybe you get help already. But I still want to share my ideas on your topic. From your specifications, the generator you are looking is a small generator with Perkins engine. You can contact Perkins generator manufacturer or supplier whether they can provide to you. Because not every supplier can produce very small generator. For small generator, I suggest you use portable generator (gasoline) that can be moved easily. Diesel generator is heavy. We are diesel generator manufacturer. For Perkins engine generator, we produce 24KW to 1800KW ( http://www.dieselgeneratortech.com/Perkins/) with various types, such as open type, silent type, trailer type, portable type and container type, etc. All the generating sets are water-cooled. But different specifications, the technical data is also different. Fuel consumption is also different.
_________________ Attitude is a little thing that makes a big difference.
| Fri Jul 06, 2018 3:26 am |
cb5331
Wtf?
| Fri Jul 06, 2018 5:09 pm |
Russ
Damn. 2013. Talk about necro. Lmao
| Fri Jul 06, 2018 5:39 pm |
