It is currently Thu Mar 28, 2024 4:40 pm
[ 3 posts ] |
NEED HELP—35 H.P MudBuddy Mikuni carb
FullStrap94
I have 35 horse MudBuddy and I just ran it not even a month ago and it ran fine for a while, then it started backfiring and at full throttle it would almost die. Now every time I pump the bulb gas comes out of the over flow tube on the bottom and it will not start. I took the bolt on the bottom and drained it and put it back in but it still shoots gas out of the over flow tube every time I pump the bulb and the motor will not start. If anyone could please give me some advice I’d greatly appreciate it.
Sun Jul 29, 2018 4:32 am |
DmaxHunter
Joined: Wed Jan 18, 2012 7:21 pm Posts: 2207 Location: North Alabama
Re: NEED HELP—35 H.P MudBuddy Mikuni carb
Sounds like a clogged jet, pull the main and remove any debris. Ethanol is hell on these motors, a stabilizer is recommended to keep this from happening.
Sent from my SM-N950U using Tapatalk
_________________ 2014 PRODIGY 1754 (#19) 2014 5500 BAMF HDR RETRO SOLD
Sun Jul 29, 2018 7:49 am |
Will C
Overflow from that line is needle/seat related. Remove float , needle then remove the seat. There is a small black oring on the seat. Inspect or replace the oring. Make sure it's clean. If it's an older motor replacing fuel lines is good. When the line starts falling apart inside it puts little black pieces into carb Wich will keep the needle/seat combo from sealing up.
Sun Jul 29, 2018 9:46 am |
[ 3 posts ] |
Users browsing this forum: No registered users and 205 guests |
