It is currently Fri Apr 19, 2024 1:14 am
[ 7 posts ] |
Oil leak Black Death 4400 questions
Ap1286
I ordered a new gasket so I have the oil leak under control. My question is I just replaced the gasket maybe 20 hours ago after changing out cams to a delta cam. Is there something special when installing this gasket or is there potentially something else wrong causing it to fail so quickly. Question number two is in the pics attached, the plates behind the belt housing, what order and direction do they go in bc either way seems to block some threaded holes. Unfortunately between work and rainy evenings and a sick baby I’ve been out here working on it when I can and it’s been about a week process. Thanks in advance for the help
Wed Aug 01, 2018 2:41 pm |
cb5331
Re: Oil leak Black Death 4400 questions
The design of the block and the bolt pattern is shit.
Wed Aug 01, 2018 3:12 pm |
GNSPEED
Teflon to belt housing,then large plate ,the two hole shim onblock,notches on bottom.they all leak but make sure to clean threads on bolt and holes then red loctite.case gasket delete helps alot.
Wed Aug 01, 2018 8:19 pm |
GNSPEED
Ap1286
Thanks guys, does the two hole shim go on top or bottom?
Thu Aug 02, 2018 4:48 am |
MaXXis85
Quit using case gaskets. That will prolong the oil leak. I machine internals and use Yamabond 4 Clean all bolt holes, bolts, and Loctite them in place.
Thu Aug 02, 2018 5:07 am |
GNSPEED
two hole shim on top against case cover
Fri Aug 03, 2018 12:26 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 218 guests |
