It is currently Wed Mar 18, 2026 3:24 pm
Reply to topic  [ 23 posts ]
 Slow excel and 37efi
Post Slow excel and 37efi
After breaking in my mb37efi. We took it out this year and only got 22mph per gps. Is that typical and what can I do with that setup for more speed..
This was empty with three people( 700 lbs)
I know I can put a cuda kit on or change to a lighter hull( mine is .125) but I feel the need for speed...
After a dog and a hunting load, it would obviously slow down more
Steve
Mon Sep 03, 2018 1:29 pm
Post Re: Slow excel and 37efi
Boat size?
#TheGhostBoat
Mon Sep 03, 2018 1:35 pm
Excel 1854
Mon Sep 03, 2018 1:43 pm
Figure that's not too far off, but it is a couple mph low. How many rpms are you turning, is your prop worn (measure it), and what does a compression test show on each cylinder?
#TheGhostBoat
Mon Sep 03, 2018 2:01 pm
Maybe 12 hours on it. Big blade. Have not done a compression test...what compression should it have and do I need to change plugs after break in?
It kinda struggled some last year with a full load
And that is about 4000-4100 rpm
Mon Sep 03, 2018 2:09 pm
Props can get worn in no time and lose some bite. Never hurts to have fresh plugs, but 12 hours isnt very many on a set. Rpms sound right, but trim level and prop wear affect that, and the ability to carry loads. Compression ought to be 150ish.
#TheGhostBoat
Mon Sep 03, 2018 2:55 pm
When all said and done you are probably going to need a stage 1 motor to feel like it's doing its job without effort
Mon Sep 03, 2018 9:39 pm
Any suggestions on a stage one kit?
BPS ?.
Mon Sep 03, 2018 11:12 pm
I wouldn't be going with the high volume places. Texasmudmotors, Bayou surface drives and a couple other good guys will take the time to do it right
Tue Sep 04, 2018 8:08 am
Tue Sep 04, 2018 8:25 am
Tue Sep 04, 2018 8:28 am
Delta is good as well.
Tue Sep 04, 2018 8:40 am
Tue Sep 04, 2018 2:10 pm
Great info...thanks for the specific shops to inquire about
What is a stable hp to expect for an increase from the 37 efi?
Don’t want it to go a season then grenade itself after 10 hours
Tue Sep 04, 2018 4:00 pm
Tue Sep 04, 2018 4:32 pm
I actually think that Briggs and Stratton translates to Grenade in all other languages.
Tue Sep 04, 2018 5:09 pm
Tue Sep 04, 2018 6:26 pm
Tue Sep 04, 2018 6:36 pm
With 36ish hours total, mind you.
Couldn't get the pic to post and was busy at work. Thanks for posting.
#TheGhostBoat
Tue Sep 04, 2018 7:12 pm
Tue Sep 04, 2018 7:37 pm
Wed Sep 05, 2018 10:23 pm
Thu Sep 06, 2018 7:05 am
Maxxiis, looked you folks up...might call and see about options
Can you recommend my next steps to get this excel moving ...heads, tuner etc??
Thu Sep 06, 2018 3:37 pm
