| Slow excel and 37efi http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=72953 |
| Author: | Okiedukk [ Mon Sep 03, 2018 1:29 pm ] |
| Post subject: | Slow excel and 37efi |
After breaking in my mb37efi. We took it out this year and only got 22mph per gps. Is that typical and what can I do with that setup for more speed.. This was empty with three people( 700 lbs) I know I can put a cuda kit on or change to a lighter hull( mine is .125) but I feel the need for speed... After a dog and a hunting load, it would obviously slow down more Steve |
| Author: | Russ [ Mon Sep 03, 2018 1:35 pm ] |
| Post subject: | Re: Slow excel and 37efi |
Boat size? #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | Okiedukk [ Mon Sep 03, 2018 1:43 pm ] |
Excel 1854 |
| Author: | Russ [ Mon Sep 03, 2018 2:01 pm ] |
Figure that's not too far off, but it is a couple mph low. How many rpms are you turning, is your prop worn (measure it), and what does a compression test show on each cylinder? #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | Okiedukk [ Mon Sep 03, 2018 2:09 pm ] |
Maybe 12 hours on it. Big blade. Have not done a compression test...what compression should it have and do I need to change plugs after break in? It kinda struggled some last year with a full load And that is about 4000-4100 rpm |
| Author: | Russ [ Mon Sep 03, 2018 2:55 pm ] |
Props can get worn in no time and lose some bite. Never hurts to have fresh plugs, but 12 hours isnt very many on a set. Rpms sound right, but trim level and prop wear affect that, and the ability to carry loads. Compression ought to be 150ish. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | Will C [ Mon Sep 03, 2018 9:39 pm ] |
When all said and done you are probably going to need a stage 1 motor to feel like it's doing its job without effort |
| Author: | Okiedukk [ Mon Sep 03, 2018 11:12 pm ] |
Any suggestions on a stage one kit? BPS ?. |
| Author: | Will C [ Tue Sep 04, 2018 8:08 am ] |
I wouldn't be going with the high volume places. Texasmudmotors, Bayou surface drives and a couple other good guys will take the time to do it right |
| Author: | kib876 [ Tue Sep 04, 2018 8:25 am ] |
| Author: | bluesky2012 [ Tue Sep 04, 2018 8:28 am ] |
| Author: | 4Cody4 [ Tue Sep 04, 2018 8:40 am ] |
Delta is good as well. Sent from my iPhone using Tapatalk |
| Author: | Glade [ Tue Sep 04, 2018 2:10 pm ] |
| Author: | Okiedukk [ Tue Sep 04, 2018 4:00 pm ] |
Great info...thanks for the specific shops to inquire about What is a stable hp to expect for an increase from the 37 efi? Don’t want it to go a season then grenade itself after 10 hours |
| Author: | Russ [ Tue Sep 04, 2018 4:32 pm ] |
| Author: | 4Cody4 [ Tue Sep 04, 2018 5:09 pm ] |
I actually think that Briggs and Stratton translates to Grenade in all other languages. Sent from my iPhone using Tapatalk |
| Author: | bluesky2012 [ Tue Sep 04, 2018 6:26 pm ] |
| Author: | JBsuperG [ Tue Sep 04, 2018 6:36 pm ] |
| Author: | Russ [ Tue Sep 04, 2018 7:12 pm ] |
With 36ish hours total, mind you. Couldn't get the pic to post and was busy at work. Thanks for posting. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | bluesky2012 [ Tue Sep 04, 2018 7:37 pm ] |
| Author: | Okiedukk [ Wed Sep 05, 2018 10:23 pm ] |
| Author: | MaXXis85 [ Thu Sep 06, 2018 7:05 am ] |
| Author: | Okiedukk [ Thu Sep 06, 2018 3:37 pm ] |
Maxxiis, looked you folks up...might call and see about options Can you recommend my next steps to get this excel moving ...heads, tuner etc?? |
