It is currently Fri Mar 29, 2024 2:15 am
[ 8 posts ] |
All hell breaking loose on prodrive?
Pinhead pat
{long post} So i had my starter rebuilt a couple weeks ago, i ran it in the yard abunch with no problems, took it out for the first time and got a few hundred yards from the boat ramp when i stopped to put some ear plugs in for a long transit. When i engaged the prop to get goin again nothin happened. I kept tryin the engage switch and the bump switch. I got the bump switch to work in and out. I got about 100 yards from the ramp when the power wire from the ignition switch to the starter caught on fire. We paddled back and went home. I replaced the wire and it caught on fire again as soon as i connected the hot wire to the battery. Upon further inspection all the wires inside of the control box were kinda fused together. I pulled em all apart and wrapped the exposed wires in electrical tape. It started up fine but still no prop engagement. I turned it off and tried again now it wont start or anything. Ive tried abunch of times. I checked all the connections and they are all good? I also replaced the engagement switch Does any problem stand out to anyone? I was thinkin maybe the wires all got fried?
Sat Sep 08, 2018 7:08 pm |
4Cody4
Joined: Thu Mar 31, 2011 11:21 am Posts: 2530 Location: Land of 10,000 Lakes
Re: All hell breaking loose on prodrive?
Seems to me that there is something causing a short or grounding out somewhere. Something is screwed up if the wires got that hot without a fuse blowing.
_________________ "Two people in this world wear helmets, and that's dare devils and pussies." - Willie Braun
Sat Sep 08, 2018 7:14 pm |
Pinhead pat
Sat Sep 08, 2018 8:45 pm |
Will C
I've had to rewire a couple. The clutch was internally shorting out on both. Not saying for sure that ur short is the same. Newer Prodrive's have a fuse installed to prevent this. Add a fuse while you are repairing
Sat Sep 08, 2018 9:00 pm |
OwenDickeson
I would do a complete re-wire. Get with Pro-Drive and give them your PD number, and hopefully they can email you some wiring schematics.
Sun Sep 09, 2018 6:27 am |
dead animal
Sun Sep 09, 2018 8:44 am |
trofazz
Joined: Thu Jun 07, 2018 4:14 pm Posts: 97 Location: Lyons, Michigan
_________________ 1854 Timber Creek, 37efi HD
Sun Sep 09, 2018 9:55 am |
Pinhead pat
I just ordered all new wires. I’ll be offshore til wednesday and i need the boast for teal opener this weekend and i dont know jack shit about clutches so im gonna leave it at a shop while im gone for the clutch then rewire when i get home. Unfortunately insurance is out of the question
Sun Sep 09, 2018 3:07 pm |
[ 8 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 342 guests |
