It is currently Wed Mar 18, 2026 2:01 pm
Reply to topic  [ 26 posts ]
 Prodrive mechanic needed
Post Prodrive mechanic needed
Looking for a mechanic in Louisiana who is familiar with prodrive motors. I have an older model that has a small oil leak and exhaust leak. Would like to get the leak fixed and exhaust changed before duck season opens. Any help would be greatly appreciated. Thanks
Sent from my SM-N960U using Tapatalk
Sun Sep 30, 2018 8:52 pm
Post Re: Prodrive mechanic needed
Prodrive is in Louisiana. Bet they have a mechanic there that knows a little about them
Sun Sep 30, 2018 11:46 pm
Where in LA are you at?
#TheGhostBoat
Mon Oct 01, 2018 7:05 am
Russ I am in Lafayette. Not looking to pay prodrive mechanic prices lol . It's an old motor
Wed Oct 03, 2018 6:48 pm
Take a picture of the oil leak and post it.
#TheGhostBoat
Wed Oct 03, 2018 6:53 pm
I used to be that guy, But I since moved to Texas.
Oil leak is usually case gasket.
That requires remving the powerhead, clutch, motor plate, cover, ect
$400 labor for removal and replace
$100 ish to machine the internals for use of Yamabond 4 sealant
$100 for fluids, filters, cleaners, rags, sealant,
Plus gaskets for whatever else is leaking. Also if the clutch is seized or spline adapter, add additional labor.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Thu Oct 04, 2018 7:05 am
Guidrys marine and outdoor is in Lafayette off ambassador and bertrand.
Sent from my SM-G960U using Tapatalk
2060 CC 3/4 Gator-tail 1/4 Brother Breaux Boat /35GTR
Cowboy thought- a thong on a woman is like a barbed wire fence. It protects the property but doesnt obstruct the view.
Thu Oct 04, 2018 5:42 pm
throw some lucas oil stop leak in the engine, and take the muffler off and bring it to t-boy to weld up. cheapest way I know how to fix it.
my pd been leaking oil for years, I just put lucas or stp in it to slow down the leak and park it with the motor trimmed up so it don't leak out overnight.
good luck.
Thu Oct 04, 2018 5:51 pm
Fri Oct 05, 2018 5:26 am
Fri Oct 05, 2018 5:27 am
Fri Oct 05, 2018 5:28 am
By the placement of the orange pooky you may have a blown head gasket. I would get it checked out asap. It could hurt more parts if not addressed.
Fri Oct 05, 2018 7:10 am
Fri Oct 05, 2018 10:01 am
if it's leakin where that orange stuff is it's probly a blown head gasket. when the motor gets hot it will leak worse. not hard or expenisve to fix if you don't let it go too long. it will rob power. get it looked at by a friend or mech when u find one.
good luck.
Fri Oct 05, 2018 6:41 pm
Pm sent. I can change it next week if you get the gasket and want to drive it up to pineville.
#TheGhostBoat
Fri Oct 05, 2018 7:18 pm
Sat Oct 06, 2018 12:47 pm
Squirting gasket sealer in between the heat sink fins isn't going to do anything... as you found out. If you aren't comfortable removing the exhaust and replacing the head gasket, I'd take Russ up on the offer. Just get a new head gasket and exhaust gaskets. Get a couple valve cover gaskets and hit Russ up to check/adjust the valves while he's at it.
Sat Oct 06, 2018 6:43 pm
Sun Oct 07, 2018 8:39 pm
Nope I was doing everything possible to stop the leak lol.
Sun Oct 07, 2018 8:59 pm
you just made a mess and more time to clean that crap off when someone has to fix it.
Bayou Surface Drive
337-351-0362
Mon Oct 08, 2018 5:48 am
Damn, Bryson. I thought my 10 year old Prodrive motor looked like crap but you have me beat!
Mon Oct 08, 2018 1:20 pm
Mon Oct 08, 2018 2:27 pm
I'm really digging the rustic look you got going on there with the touches of fall colors added, very well done lol :D
Mon Oct 08, 2018 6:13 pm
Lol well got the head gasket changed out. Everything cleaned up. Running like a champ again!!! Did the gasket my self. Wasnt to bad
Fri Oct 12, 2018 11:40 am
Fri Oct 12, 2018 11:42 am
