It is currently Tue Apr 16, 2024 3:19 pm
Reply to topic  [ 18 posts ]
 Striped out a bolt...
Post Striped out a bolt...
OK, the motor is a 4400 HDR 2yrs old. I over torqued one of the 4 bolts that hold the valve cover on. Should I just get the next size bigger bolt or put a Helicoil in it... never have done this before.. Any advice would be appreciated...
Thanks
Lead, Follow or Get The Hell Out Of The Way!!!!
1754 Gator Trax Hybrid, Hunt Deck ,with MB 4400 Black Death HDR, Duck Slaying, Mud Slingin Machine!!!
Sun Oct 07, 2018 7:37 pm
Profile YIM
Post Re: Striped out a bolt...
longer bolt should catch enough to hold or nut on bottom of longer bolt
Sun Oct 07, 2018 7:52 pm
Helicoil works too, but the longer bolt with a nut is the best idea.
#TheGhostBoat
Sun Oct 07, 2018 8:44 pm
Mon Oct 08, 2018 4:02 am
Profile YIM
Once that heat shield is out of the way, the lower 2 are easy to reach. Same with the upper 2, just a different heat shield.
#TheGhostBoat
Mon Oct 08, 2018 5:36 am
Why not install a stud in the head and you won't have this problem again? Should probably come from the factory with studs in the heads but they don't so that should be one of the first corrections made at first valve setting.
Mon Oct 08, 2018 9:54 am
Tue Oct 09, 2018 6:41 pm
Profile YIM
Helicoil is the best way. The heck with pulling a heat shield for a valve adjust.
Wed Oct 10, 2018 5:01 am
Wed Oct 10, 2018 8:13 am
Helicoil it real quick and be done with it. Don't be scurred.
Wed Oct 10, 2018 8:29 am
Wed Oct 10, 2018 2:36 pm
Fri Oct 12, 2018 11:32 am
Fri Oct 12, 2018 4:42 pm
Profile YIM
Mon Oct 15, 2018 12:33 pm
Mon Oct 15, 2018 2:54 pm
Profile YIM
This is MMT. That Guy is always trying to bust someones balls, Hes probably a good feller overall. He does bump his chest every once in a while on here.
Tue Oct 16, 2018 5:33 am
Tue Oct 16, 2018 8:53 am
Tue Oct 16, 2018 8:55 am
Users browsing this forum: No registered users and 155 guests
