It is currently Fri Mar 20, 2026 5:26 pm
[ 7 posts ] |
New 23 Vanguard electric start not working
Eaglecliff
Brand new motor I got a week ago on my backwater, When i first got it the electric start worked for 3-4 times, now it doesnt do anything, pull start still works. Battery is charged and everything else obvious is in order. I did notice that the white wire coming out of the ignition isnt connected to anything unlike the other 4 or 5 wires. I dont see anything that the wire wire could connect to. Am i missing something?
| Fri Oct 19, 2018 6:37 pm |
W_HILL
New Member
 Re: New 23 Vanguard electric start not working
I don't believe that white wire is supposed to connect to anything. The plug on the back of your ignition switch may have come loose
Sent from my LG-TP260 using Tapatalk
| Fri Oct 19, 2018 6:57 pm |
Russ
Post pics of what you're describing, then go dig through the service manual while you await a response from someone that knows these particular engines.
| Fri Oct 19, 2018 8:15 pm |
Bigen
I think everyone needs a powerprobe. Is the white wire positive or ground or open?
| Sat Oct 20, 2018 9:18 am |
Eaglecliff
heres a picture...
| Sat Oct 20, 2018 5:00 pm |
Russ
Between the two posts on the starter solenoid, is there a connection for that white wire? The solenoid needs a signal that you turned the key to engage. I'm guessing it's that white wire.
| Sat Oct 20, 2018 5:20 pm |
Eaglecliff
turns out it was the tilt switch, the motor has to be so high for the electric start to work..
| Mon Oct 29, 2018 6:11 pm |
[ 7 posts ] |
