| New 23 Vanguard electric start not working http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=73134 |
| Author: | Eaglecliff [ Fri Oct 19, 2018 6:37 pm ] |
| Post subject: | New 23 Vanguard electric start not working |
Brand new motor I got a week ago on my backwater, When i first got it the electric start worked for 3-4 times, now it doesnt do anything, pull start still works. Battery is charged and everything else obvious is in order. I did notice that the white wire coming out of the ignition isnt connected to anything unlike the other 4 or 5 wires. I dont see anything that the wire wire could connect to. Am i missing something? |
| Author: | W_HILL [ Fri Oct 19, 2018 6:57 pm ] |
| Post subject: | Re: New 23 Vanguard electric start not working |
I don't believe that white wire is supposed to connect to anything. The plug on the back of your ignition switch may have come loose Sent from my LG-TP260 using Tapatalk |
| Author: | Russ [ Fri Oct 19, 2018 8:15 pm ] |
Post pics of what you're describing, then go dig through the service manual while you await a response from someone that knows these particular engines. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | Bigen [ Sat Oct 20, 2018 9:18 am ] |
I think everyone needs a powerprobe. Is the white wire positive or ground or open? |
| Author: | Eaglecliff [ Sat Oct 20, 2018 5:00 pm ] |
heres a picture... |
| Author: | Russ [ Sat Oct 20, 2018 5:20 pm ] |
Between the two posts on the starter solenoid, is there a connection for that white wire? The solenoid needs a signal that you turned the key to engage. I'm guessing it's that white wire. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | Eaglecliff [ Mon Oct 29, 2018 6:11 pm ] |
turns out it was the tilt switch, the motor has to be so high for the electric start to work.. |
