It is currently Fri Mar 29, 2024 2:09 am
Reply to topic  [ 19 posts ]
 Starter dragging question
Post Starter dragging question
I have 2 batteries. One for engine and other for accessories. When I try to crank motor the starter drags. I hook another battery to it via jumper cables and it fires right up. Figured it is a bad battery. Battery voltage is 12.51 volts. The battery I jumped it with is 12. 72 volts. Could it still be a bad battery at 12.51 volts?
Thu Nov 15, 2018 3:45 pm
Post Re: Starter dragging question
What motor you running? The 40s all do that for some reason
Thu Nov 15, 2018 4:24 pm
2011 35GTR that I did alot of work to. Thinking it might be a bad cell causing a drop in amperage.
Thu Nov 15, 2018 4:26 pm
Battery issue.
#TheGhostBoat
Thu Nov 15, 2018 6:17 pm
Figured Russ might have an idea since he has a bunch of starter issue experience.
I swapped batteries around and that is all it was. Must be a bad cell in the battery.
Fri Nov 16, 2018 11:42 am
Has it always don’t that or just recently started? Mine started after mods which leads me to beleive it is lagging a little
Due to the extra compression.
Fri Nov 16, 2018 3:43 pm
Fri Nov 16, 2018 9:48 pm
The old model starter doesn't even drag with mine at 217 compression. The current starters are high torque versions, so if it's dragging, there's a problem and it's not compression.
#TheGhostBoat
Sat Nov 17, 2018 3:10 pm
Mine just started lagging. Switched batteries and problem resolved.
Sat Nov 17, 2018 3:16 pm
I have a 40 briggs. the starter drags all the time. I figure I got a bad wire somewhere. when it won't crank i'll figure it out.
Mon Nov 19, 2018 9:03 pm
My 40 was dragging before and after mods, just figured out my battery is sulfated so I'm reconditioning it to see if that helps.
Wed Nov 21, 2018 3:09 pm
I found something out on my 40. If you turn the key on and let the fuel pump run and don't try to crank for about 15 seconds, it doesn't drag. Maybe some of y'all can try that and see if it helps, I know it doesn't drag at all on mine when I do that
Thu Nov 22, 2018 9:04 am
I usually just turn the crank and go. I don't wait for anything. not interested in waiting for any amount of time. that's brigg's problem. lol
Thu Nov 22, 2018 9:43 am
Lol just thought you would be happy I found a possible solution lol
Thu Nov 22, 2018 9:57 am
Thu Nov 22, 2018 8:11 pm
I tried it this am. yep, u 2 guys win the internet today. I waited till the pump stops makin noise and it cranks easy. lol
Fri Nov 23, 2018 1:37 pm
Fri Nov 23, 2018 3:44 pm
:D :D :D :D :D :D :D
For some reason, I'm stoked about this lol I'll have a whiskey and coke for you bro lol
Fri Nov 23, 2018 4:12 pm
i'm probly 2 or 3 ahead of you!!! lol
Fri Nov 23, 2018 6:42 pm
Users browsing this forum: Majestic-12 [Bot] and 337 guests
