It is currently Fri Nov 27, 2026 5:12 pm
Reply to topic  [ 9 posts ]
 Vanguard 35 block bolts torque setting and sequence ?
Post Vanguard 35 block bolts torque setting and sequence ?
Hello,
I was reading through the forums and saw several posts about oil leaking, block gaskets and the need to torque the block some time after the break in period. I have recently bought a 2012 GTR with a 35 Briggs Vanguard engine and have noticed a very small amount of oil leakage at the seam above to the left of the oil filter on occasion. I want to try to torque the bolts because I don't know if its ever been done and it might just tighten up some. Can anyone tell me the torque setting and if there should be a sequence to torque the bolts?
Fri Nov 30, 2018 6:40 am
Post Re: Vanguard 35 block bolts torque setting and sequence ?
Check the sticky in the engines section for torque numbers, and I'll look for the torque sequence. It's been posted a few times.
#TheGhostBoat
Fri Nov 30, 2018 8:09 am
As Russ said, check the sticky for more information. Good stuff there. Here is a post with the torque sequence:
viewtopic.php?f=3&t=15860&start=40
2010 GTR35 pushing an 1860 Gator-Tail Extreme
Fri Nov 30, 2018 10:35 am
if Its leaking, Send it to someone to do a gasket delete/ machine the internals of the motor. From there your issues will go away.
Fri Nov 30, 2018 1:56 pm
Thanks very much for the information. I' m new to the forum and will look for the " stickies". I took a screen shot of the sequence.
I am going to change the oil and filter today and put the 2 1/2 quarts recommended by Duval at Gator Tail yesterday. He said use 15W -50 full synthetic. I have not figured out how to get my motor to be completely level to check it with the dipstick. going to work on that.
Thanks again.
paulo985
Sat Dec 01, 2018 7:31 am
I found where it says stcky at the bottom of the page when looking at the Engines & Engine Mod Talk page, but I have tried to click on it to open with no success.
Sat Dec 01, 2018 8:01 am
https://r.tapatalk.com/shareLink?url=ht ... are_type=t
#TheGhostBoat
Sat Dec 01, 2018 8:15 am
#TheGhostBoat
Thanks so much Russ, more than I hoped for. Really appreciate this.
Sat Dec 01, 2018 4:31 pm
