Vanguard 35 block bolts torque setting and sequence ?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=73276
Author:  Paulo985 [ Fri Nov 30, 2018 6:40 am ]
Post subject:  Vanguard 35 block bolts torque setting and sequence ?
Hello,
I was reading through the forums and saw several posts about oil leaking, block gaskets and the need to torque the block some time after the break in period. I have recently bought a 2012 GTR with a 35 Briggs Vanguard engine and have noticed a very small amount of oil leakage at the seam above to the left of the oil filter on occasion. I want to try to torque the bolts because I don't know if its ever been done and it might just tighten up some. Can anyone tell me the torque setting and if there should be a sequence to torque the bolts?
Author:  Russ [ Fri Nov 30, 2018 8:09 am ]
Post subject:  Re: Vanguard 35 block bolts torque setting and sequence ?
Check the sticky in the engines section for torque numbers, and I'll look for the torque sequence. It's been posted a few times.
#TheGhostBoat
Author:  deucem [ Fri Nov 30, 2018 10:35 am ]
As Russ said, check the sticky for more information. Good stuff there. Here is a post with the torque sequence:
viewtopic.php?f=3&t=15860&start=40
Author:  MaXXis85 [ Fri Nov 30, 2018 1:56 pm ]
if Its leaking, Send it to someone to do a gasket delete/ machine the internals of the motor. From there your issues will go away.
Author:  Paulo985 [ Sat Dec 01, 2018 7:31 am ]
Thanks very much for the information. I' m new to the forum and will look for the " stickies". I took a screen shot of the sequence.
I am going to change the oil and filter today and put the 2 1/2 quarts recommended by Duval at Gator Tail yesterday. He said use 15W -50 full synthetic. I have not figured out how to get my motor to be completely level to check it with the dipstick. going to work on that.
Thanks again.
paulo985
Author:  Paulo985 [ Sat Dec 01, 2018 8:01 am ]
I found where it says stcky at the bottom of the page when looking at the Engines & Engine Mod Talk page, but I have tried to click on it to open with no success.
Author:  Russ [ Sat Dec 01, 2018 8:15 am ]
https://r.tapatalk.com/shareLink?url=ht ... are_type=t
#TheGhostBoat
#TheGhostBoat
Author:  Paulo985 [ Sat Dec 01, 2018 4:31 pm ]
Thanks so much Russ, more than I hoped for. Really appreciate this.
