It is currently Thu Mar 28, 2024 11:23 am
[ 6 posts ] |
zspanhanks
New Member
Rev Limiter
Any way to test an early model rev limiter? I seem to bang out on top end and not sure if limiter working.
Fri Nov 30, 2018 1:17 pm |
dead animal
Re: Rev Limiter
put it in neutral and rev it up till it cuts out while watching the tach.
Fri Nov 30, 2018 5:54 pm |
zspanhanks
New Member
Re: Rev Limiter
Tach not working right, gives screwed up rpm. Was looking for check with a meter. Thanks for the reply, good hunting,
Sun Dec 02, 2018 6:29 pm |
JBsuperG
Joined: Wed Mar 21, 2018 2:51 pm Posts: 263 Location: Michigan
Re: Rev Limiter
You can get a new tac for $20
Sun Dec 02, 2018 6:32 pm |
Buckmark311
Re: Rev Limiter
make sure your tac wire isn't touching something its not supposed to be. Was havaing issue with mine and noticed it was touching another wire. re-routed it and no issues.
Mon Dec 03, 2018 10:47 am |
JBsuperG
Re: Rev Limiter
They will also mess up if the wires are getting wet?. Mine used to get spray from the motor and read very high. Once I was able to block that spray it worked just fine
Mon Dec 03, 2018 1:09 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 223 guests |
