| Rev Limiter http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=73279 |
| Author: | zspanhanks [ Fri Nov 30, 2018 1:17 pm ] |
| Post subject: | Rev Limiter |
Any way to test an early model rev limiter? I seem to bang out on top end and not sure if limiter working. |
| Author: | dead animal [ Fri Nov 30, 2018 5:54 pm ] |
| Post subject: | Re: Rev Limiter |
put it in neutral and rev it up till it cuts out while watching the tach. |
| Author: | zspanhanks [ Sun Dec 02, 2018 6:29 pm ] |
Tach not working right, gives screwed up rpm. Was looking for check with a meter. Thanks for the reply, good hunting, |
| Author: | JBsuperG [ Sun Dec 02, 2018 6:32 pm ] |
You can get a new tac for $20 |
| Author: | Buckmark311 [ Mon Dec 03, 2018 10:47 am ] |
make sure your tac wire isn't touching something its not supposed to be. Was havaing issue with mine and noticed it was touching another wire. re-routed it and no issues. |
| Author: | JBsuperG [ Mon Dec 03, 2018 1:09 pm ] |
They will also mess up if the wires are getting wet?. Mine used to get spray from the motor and read very high. Once I was able to block that spray it worked just fine |
