It is currently Thu Nov 26, 2026 4:39 pm
Reply to topic  [ 11 posts ]
 45 Mag 1 Cylinder Not Firing
Post 45 Mag 1 Cylinder Not Firing
Posting for a friend:
New coils, new spark plugs both sparking. Bypass kill switch no change. Cleaned carb, .005 valve clearance. 190 compression and passed leak down. Rods are straight.
Any ideas?
2016 Prodrive X 1848 37efi
Sun Dec 09, 2018 8:37 pm
Post Re: 45 Mag 1 Cylinder Not Firing
Check the diodes that connect to the coils.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Sun Dec 09, 2018 11:26 pm
If it's cylinder #1 I've seen the the vacuum fuel pumps leak fuel into the pump signal line flooding the num1 cylinder
Mon Dec 10, 2018 12:25 am
Mon Dec 10, 2018 7:16 am
He says his engine doesn't have diodes connected to the coils on his engine and if you're standing behind the boat it's the right side not working
Mon Dec 10, 2018 12:38 pm
That would be cylinder number 2. That eliminates the possibility of the fuel pump. Next I would remove cowling and inspect the intake gasket going to the head. Gasket may be popped.
Tue Dec 11, 2018 12:13 am
Turned out to be a bad oil sensor
Tue Dec 11, 2018 12:36 pm
Nevermind... Problem is back
Tue Dec 11, 2018 7:34 pm
Problem was just in the carb setup. It's alive and running good now
Fri Dec 21, 2018 10:45 am
Found that I am having the same problem. Right side standing behind the motor doesnt appear to be firing. What did you find in the carb setup that created the problem? I found mine not firing when trying to adjust the idle. I cannot get the motor to idle properly at all.
Fri Dec 21, 2018 10:38 pm
When it came in I noticed a idle fuel screw broken off in carb. Set valves, it passed a leakdown . I got the broken screw out and freshened up carb. Ran good after that
Sun Dec 23, 2018 8:52 pm
