| 45 Mag 1 Cylinder Not Firing http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=73323 |
| Author: | Exbellicus [ Sun Dec 09, 2018 8:37 pm ] |
| Post subject: | 45 Mag 1 Cylinder Not Firing |
Posting for a friend: New coils, new spark plugs both sparking. Bypass kill switch no change. Cleaned carb, .005 valve clearance. 190 compression and passed leak down. Rods are straight. Any ideas? |
| Author: | lastchance [ Sun Dec 09, 2018 11:26 pm ] |
| Post subject: | Re: 45 Mag 1 Cylinder Not Firing |
Check the diodes that connect to the coils. Sent from my SAMSUNG-SM-G935A using Tapatalk |
| Author: | Will C [ Mon Dec 10, 2018 12:25 am ] |
If it's cylinder #1 I've seen the the vacuum fuel pumps leak fuel into the pump signal line flooding the num1 cylinder |
| Author: | MaXXis85 [ Mon Dec 10, 2018 7:16 am ] |
| Author: | Exbellicus [ Mon Dec 10, 2018 12:38 pm ] |
He says his engine doesn't have diodes connected to the coils on his engine and if you're standing behind the boat it's the right side not working |
| Author: | Will C [ Tue Dec 11, 2018 12:13 am ] |
That would be cylinder number 2. That eliminates the possibility of the fuel pump. Next I would remove cowling and inspect the intake gasket going to the head. Gasket may be popped. |
| Author: | Exbellicus [ Tue Dec 11, 2018 12:36 pm ] |
Turned out to be a bad oil sensor |
| Author: | Exbellicus [ Tue Dec 11, 2018 7:34 pm ] |
Nevermind... Problem is back |
| Author: | Will C [ Fri Dec 21, 2018 10:45 am ] |
Problem was just in the carb setup. It's alive and running good now |
| Author: | Fowl Play [ Fri Dec 21, 2018 10:38 pm ] |
Found that I am having the same problem. Right side standing behind the motor doesnt appear to be firing. What did you find in the carb setup that created the problem? I found mine not firing when trying to adjust the idle. I cannot get the motor to idle properly at all. |
| Author: | Will C [ Sun Dec 23, 2018 8:52 pm ] |
When it came in I noticed a idle fuel screw broken off in carb. Set valves, it passed a leakdown . I got the broken screw out and freshened up carb. Ran good after that |
