It is currently Thu Nov 26, 2026 4:22 pm
Reply to topic  [ 16 posts ]
 Stainless stee valves yes or no
Post Stainless stee valves yes or no
What is the deal with the briggs and the SS valves. As far as I know, everyone who is running a Kawasaki that is modded, is still running stock valves. Are the stock briggs valves that shitty? Has anyone had one break? reason I ask, I pulled a friends set of heads, stock valves and springs. Hes asked me to help him out. So we ported the heads, decked .050", I lapped the stock valves and back cut them. I didn't shim the stock springs, but could (don't know where to get the shims). Hes just looking for a little more juice. Fired up without a hitch.
So my question is what is the big issues with the briggs SS valves? Are they bigger which would require you to recut the valve seat. Are they that much stronger, like I mentioned I ran stock valves in my kawi as well as many others turning 4800+ rpms.
Wed Dec 19, 2018 4:23 am
Post Re: Stainless stee valves yes or no
They're a 1 piece valve. No weld to fail.
#TheGhostBoat
Wed Dec 19, 2018 8:24 am
Factory valves for factory repairs, anything performance gets bigger SS valves for durability and they allow for a better valvejob which makes more power
Wed Dec 19, 2018 9:15 am
I'm tearing into this Sport V and just trying to get all this shit correct before I try to even mount the engine back for a test run.
Wed Dec 19, 2018 9:30 am
Hell call you back in about 50-100 hours when his exhaust valve breaks and puts a hole in the piston and spits it out the exhaust... Need a piston, rod, and head.. All for saving 30 dollars per valve.
Also lapping valves may help seal, BUT a 3-4 angle valve job ALONE will increase performance.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Wed Dec 19, 2018 10:02 am
Damn.
Wed Dec 19, 2018 10:50 am
I was told that these were Manley, one piece, stainless steel valves installed in my motor.
Wed Dec 19, 2018 2:10 pm
Damn Troy. Normal running?
Wed Dec 19, 2018 5:17 pm
that sucks!!! I use my motor more than most on here, so I run whatever is on a stock motor and will do that until warranty is over or I get a different engine. mods are for high rollers like you fine gentlemens!!!!
Wed Dec 19, 2018 7:19 pm
Thu Dec 20, 2018 10:02 am
Talk about ruining a sunset. Having to shuttle blue around...
#TheGhostBoat
Thu Dec 20, 2018 10:14 am
LOL ....that and me having to drive GTR’s the rest of the weekend....
....true story
Thu Dec 20, 2018 1:04 pm
That is a delta head I can tell by the deshroud shape. Ive personally seen 1 Manley fail. Its a fluke...If it were another issue it would be way more apparent..
Bayou Surface Drive
337-351-0362
Thu Dec 20, 2018 2:49 pm
So I'm assuming the delta heads and other kinds don't do that very often?
Thu Dec 20, 2018 7:37 pm
Bayou Surface Drive
337-351-0362
Fri Dec 21, 2018 7:49 am
Fri Dec 21, 2018 9:59 am
