It is currently Tue Nov 24, 2026 2:19 pm
[ 5 posts ] |
25hp Mudbuddy Mini & G3 1548
btempleton13
I am very new to surface drives, so any help is greatly appreciated. Can you please explain how to use a surface drive from the beginning to the end?
I have a 1548 G3 hull and a 25HP Mudbuddy Mini. I am able to get on plane with myself and one other in the boat but any time I or put any gear in the boat it boggs down. Is my hull too heavy for the engine to push? Am I not trimming properly?
I just purchased a new prop so that's hopefully out of the question.
| Mon Dec 17, 2018 6:25 pm |
Will C
 Re: 25hp Mudbuddy Mini & G3 1548
First the engine should pass a health check. Yes it's possible with your setup that you may find the limit of power easily. The prop to run should be an 11x10 I believe. Make sure you don't have a tall transom motor on a short transom boat also
| Mon Dec 17, 2018 6:35 pm |
btempleton13
I discovered I have a short transom motor on a tall transom boat. Would that be why I'm having issues?
| Wed Dec 19, 2018 2:15 pm |
Will C
Its definitely not helping anything. I can't say that correcting it will make it do the job though
| Wed Dec 19, 2018 2:43 pm |
bluesky2012
That’s a baby sized motor on a not right hull. Not sure what you expected.
| Wed Dec 19, 2018 9:06 pm |
[ 5 posts ] |
